Anyone made a Lutec?
Started by Craigy, January 09, 2007, 12:52:11 PM
brian334
ALFPARTS
It's very curious. Lutec does not answer the phone or emails. They have also been mecilessly sued by the high Court there. Also there device looks a lot like a Kawai Engine. Anybody know what that is ? :)
ALFPARTS
Quote from: potatogunman on November 18, 2008, 10:28:01 PM
heres a pic from the Lutec patent   i think im going to try  this one
theres the site i got it from    http://www.google.com/patents?id=gdgNAAAAEBAJ&dq=6630806
The Lutec looks like a ripoff of the Kawia engine.
ALFPARTS
Quote from: Vonkentrekker on December 05, 2008, 08:11:17 PM
Don't bother. The Lutec is a hoax. The 'inventors' use the wrong measurement equipment which shows meaningless figures. I've had some detailed reports about the Lutec device and when applying the proper math to it, it turns out the efficiency is around 75% and not 200%.
And it is easy to explain: a magnet cannot output power. You will probably say that a magnet can hold things. However, without motion there is not power output. Now you will say that a magnet can move objects as well. True, but the energy required to pull the object towards the magnet is the same as the energy required to pull the objects away so the net result is still zero.
A magnet is like a catalyst in chemical reactions. It helps to make something work.
The Lutec is a bogus rip-off but actually magnets are high temperature gravitational superconductors
