Motor search for lenz less or lenz assisted.
Started by MagnaProp, May 03, 2021, 12:24:02 AM
kolbacict
https://overunity.com/18854/motor-search-for-lenz-less-or-lenz-assisted/dlattach/attach/183542/
Will this effect work in case of lower frequency oscillations?
For example, swinging a pendulum?
p.s. At least with a magnet from below the iron pendulum, you can quickly change the period of its oscillation. Without stopping pendulum. ;)
synchro1
Quote from: kolbacict on November 09, 2021, 05:39:10 AM
The Hendershot does that.
synchro1
Skilling replicated it. 500 khz sounds  roughly around where that oscillation is on the EM!
synchro1
synchro1
Lidmotor generates 70 volts of power with an oscillation between the magnet and the inductor.
Below we can see the legs of the permanent horsehoe magnet at the top and the two solinoids and keeper at the bottom. This "Hendershot" is basically a scaled up Reed Switch!
