Lüling magnet motor by Ufopolitics
Started by hartiberlin, September 27, 2021, 08:53:14 PM
forest
Fully mechanical system looks good to me, pneumatic motor - well you should explain how you want to sustain air pressure without expending energy. Long time ago I posted old patent with fully rotational magnetic motor fully mechanical system using ratchet device. Sorry, I don't know patent number , but would try to find it if you are interested.
Ufopolitics
Quote from: forest on February 01, 2022, 02:34:31 PM
Thanks Forest,
I am working currently on a fully mechanical motor...and I know it will be finished in a couple of weeks...it is for demonstration purposes that it can be done.
Magnets have incredible Energy, We just have not being able to harness it ...yet.
The Pneumatic System could work in a closed circuit, where exhaust from valves and pistons are collected to a lower pressure tank, then through a purge pump it goes back to main pressurized tank.
Also a small compressor could be used as the "purge pump"
Pneumatics Closed Systems do exists, basically when they work on dirty environments or in Hospitals, where the air should be kept pure and clean...so we do not have to "invent them"...
I believe (and I will confirm this, once I finish my mechanical setup) that Lüling had a fully mechanical motor built, as he utilized pressurized air to accelerate, decelerate as maybe Hydraulics as well to set reverse rotation drive...
Yes please, I would like to see that magnet motor Patent using ratchet device...if you could find it...thanks!!
My System will work based on Levers and Springs...High and Low mechanical pressure system...and not that complicated...
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
forest
Ufopolitics
Quote from: forest on February 02, 2022, 10:22:10 AM
Ok, I found it.
Thanks Forest!!
Unbelievable!!, a Patent from 1913-1914...A Mechanical Magnet Motor, self running, just a little push and starts...
It uses attraction to run, based on steel plates arc, or Ramp actuated on and off by the mechanical ratchet system...pretty simple.
It is not the same principle as I am working on, but it is very interesting.
I just went over the explanation and graphics real quick...I will do a slow reading later on.
But many thanks Forest!!
Cheers
Ufopolitics
―Leonardo da Vinci
knovos
I'm still working on my mechanical ideas for the Luling motor but want to show up here when I have something useful. Showing drawings or animations that might work ar often a kind of pollution ;D Amazing that old paper from 1913! Maybe this was an inspiration for Luling.
