Maybe some NEW info?
Started by Johan_1955, November 12, 2021, 07:03:06 AM
sm0ky2
I dont think it is so much of a mental block.
I am always trying new things or trying things new ways
in search of a better way of doing things.
For me its more force of habit. Imagine getting into your car
one day and sitting backwards in your seat. Driving in reverse
all the way to work.
You know that left is right right is left
You can make the turns, navigate the city
Then one turn, seems so easy so natural
you turn left to go left (forgetting that your backwards)
and the car goes to the right.
My mind tells me the diode sends electricity this way,
NOT the other.
It's difficult to envision an electron Venturi Siphon
Where the (off) diode can create a void drawing electrons in
I beefed up my EB to see if that helped.
0.5v @ 0.5ma (1/4 mw)
added an impedance between the live and diode bridge
and another between the aerial and the other side of the bridge
a 3rd diode to the 2nd ground forming a loop.
Diodes are open (on), although no visible light is being produced
I left it running. Voltage is holding steady
It has ionized the air in my room overnight
I woke up to the heavy smell of Ozone.
I see no difference through the circuit with or without the aerial
Diodes are just dropping the voltage, nothing more that i can see
Outside the circuit is a high potential electric field
Strongest near the connection points. Seems to sit outside the wires
I guess facing outwards, as my hv probe collapses when i make contact
so the circuit itself is the - side of the electric field.
(the whole thing could be acting as a giant charged plate)
Im not sure what kind of power levels that represents, but its working better
than the (powered device) Ionizer i bought that i never use.
Think i should leave a window open when im playing with this.
There are a lot of unknowns here about Nigel's situation,
as was mentioned there could be ground faults
in the electrical system to his building(s),
we don't know if there is a high tension line overhead (which would raise air potential)
But more importantly- how is he tricking the ions to flow INSIDE the circuit???
sm0ky2
sm0ky2
Single ground power operating joule thief
3-diodes center tapped to 2nd ground
Free Energy - courtesy of Nigel 'Hands' Cheese
https://youtu.be/mdjlRGJaFdQ
There is 0 potential voltage between the 1st and 2nd ground wires
by themselves,
sm0ky2
this JT has a battery that can recharge, so i turned the switch on
just to see what happens. (i doubt i am reaching the charging threshold)
Im reading 0.3v at the output terminals, 0v at the input
0 from coil to the transistor
0 across the base resistor
0 between the 2 ground wires (as expected - short)
0 when i disconnect
(i'll post a follow up in a few hrs if the battery takes a charge)
Ionic trickery i tell you
sm0ky2
Its the - side of the EB too
The + side is completely disconnected
Terminal was planted 200ft from any residential electrical circuit
It may be too early for me to say this but....
I think this could be done with a large chunk of metal or
dare i say a supercap and some resistors
Simply to act as an ion sink and sort of delay to loop them
back on themselves.
0 + 0 = 2x infinity
