Maybe some NEW info?
Started by Johan_1955, November 12, 2021, 07:03:06 AM
Floor
Most likely...    it's radio frequency / electric smog.
But then we already knew this ....
Does it work in a Faraday cage ?
Probably not, but even if it doesn't, this would not prove that the energy source is
conventional electric smog.  Only that the source (what ever it is) is blocked by a
Faraday cage.
If I was going to isolate the circuit within a Faraday cage.
I would first, test to see that the cage is effective against all kinds conventional radio
reception. I would put a radio receiver in the cage and make sure it blocks effectively.
example ...  My cell phone still receives a call while inside my microwave oven (not when running).
That receptacle  / circuit is not properly grounded.
Next
I would find a     canyon   location in which all radio, TV, cell phone and satellite
reception is blocked and test the device there.
Odds are, that either one,    a working Faraday cage   or     a suitable canyon   will cause the
device to no longer function.
sm0ky2
Quote from: Floor on December 09, 2021, 01:31:25 AM
Faraday cage.
Next
Yes it works inside multiple Faraday cages (made of different metals),
as well as inside nested cages, or even using the cage itself as an ion source.
I have eliminated most high frequency signals as a source,
However it is possible for SLF and UHF to pass right through such a cage,
or be absorbed by large pieces of metal.
The visible pulses (dimming and brightening of the LEDs) are around 55Hz,
determined by an optical diode sensor circuit
If this were a half-wave rectification, it would point to the 110SLF used by (airforce i believe)
I also took it to a local 'no-zone' last night, where there is no cellular reception
It could be some sort of extraterrestrial (stellar) source, as hinted to by the inventor.
In either case, it seems to work anywhere, and cannot be blocked by conventional means.
It is also important to note here that a normal rectified radio signal induces voltage and current
through the circuit.
This circuit appears to run with 0 power, at least from the perspective of our meters.
In fact, electronics engineering fails when examining this circuit.
Its' a trick to tease it out into capacitors so we have it in our normal form to analyze it.
I know everyone wants to find some common explanation so they can say 'look! It was nothing!'
This was my first instinct as well, however this is much different than things i have encountered
in the past.
I believe there is some valuable knowledge to be gained from this, perhaps about ionic current,
Perhaps about diodes, some deep level science we don't have the equipment for....
The power i am able to obtain is insignificant at the current state
The inventor has demonstrated much more than i have been able to.
I'm at a standstill with this tech, work as it may, if i can't bring it to useful levels,
it is of no use to me.
Floor
Thanks SmOky2
Not being cynical, just healthy skepticism on my part.
Also,  up until your last post, I don't see any where in the topic,
where you have clearly stated most of the below.
Quote from: sm0ky2 on December 09, 2021, 06:31:30 AM
in the past.
           Thanks again
              best wishes
ramset
FE researchers and experimenters
https://www.overunityresearch.com/index.php?topic=4120.msg96619;topicseen#msg96619
Post #73
I did not ask his permission yet to post this here ( I feel it needs its own topic)
However I wanted to share it ..broli is wonderful open source researcher
Respectfully
Chet K
Edit
I also see he has topic here too
https://overunity.com/18852/a-solid-state-homopolar-motor/msg557375/#new
I should have checked first...a bit off here... COVID is doing a number on me .
Thanks Grandma
Johan_1955
Quote from: ramset on December 10, 2021, 10:16:29 AM
Post #73
Respectfully
Chet K
Edit
Chet, Why this here, think its not CV / Influenza but Your Vaccine?
