Build 2
Started by Johnsmith, December 22, 2021, 08:33:09 PM
Johnsmith
 I happen to like this video and while I am not deaf, I don't have normal hearing. It is possible that I'll create a field in
science called atmospheric chemistry and astrophysics. https://www.youtube.com/watch?v=GUh4JnmcyAE
Basically both Einstein and Newton missed something in their work. And Bessler's wheel would help to explain it.
Gravity has energy.
This is Suicide Squad I didn't link; https://www.youtube.com/watch?v=GUh4JnmcyAE
grave  to gravity       leve to levity
The nudibranch compared slug with 'house'  weight velocity,normal-average and maximum
        Is being still ( standing,sitting,laying)~no (external,visible)movement not the best input/output ratio case ?
The vid dog,bulldog tipo Mastinho, its weight and velocity,normal,average and maximum
         Is being still ( ...) ..........        not the best input/output ratio case ?
                             input/output ratio from a.pressure b.force c. energy d power
                          movere to mover       and motere to motor  : why the difference,target ~ motiv(e) ?
                          motiv substantive           image                         to verbe  motivare
                           votive                      word /"inner" voice                             votare
                            MOTIVATIONSTRENGHT  versus  Masse(n)traegheit/INERTIA ( the law of least resistance)
                            MOTIVATION-FREEDOM degrees : rotatory,translatory,linear ( mechanical or swing/wave)
dignitas and angustia    dignity and "Angst"/fear/Ehre(Furcht)/hono(u)r
The gravity from "sound and words and image " effect energetical : CYMATICS videos !
A right ,in ortographic manner - by layman - and meaning and communication partner understanding and time investment for clarification - by each side repeat and ever review
against from understanding from foreign ( for one from the expression user ) term and meaning or use in social class or generation class or locality
Discussion in p(e)ace or aggressive manner,for both sides win/win or one side lost : defeat,capitulation,death !
CYMATICS vids shows the chance/risc about right/wrong communication instrument use,included memory info storage [instinct : DNA/RNA and Chromo-(image)Som(sound,speak) )]and the danger/luck for good/bad first impression ' compensation/revanche' !
A word ,an image, can be like a weapon/bomb in energetic effect ! Mobbing ! Fake society parts !
People,which use foreign expressions - by good intention - in the wrong place/time/context !
Friend or Foul !?
The basic intention in ou.com : the free energy machine
Bessler wheel : Hjulkors,Sunwheel,Suncycle  :
Sun(or Son or Sonn) -Planet-wheel(s)Transmission to Automatic Transmission to Gyro gear
wmbr
OCWL
p.s.: and never forgetting that we are human ,with concentration/or not,with 100%rules and laws application/or not,with body deficiencies ( since birth,by genetics, or over our life,by  organs and extremities friction )
Nobody is,will be,perfect !
Either not the Superduper-Robot from BOSTON DYNAMICS integrated wit CAMBRIDGE ANALYTICA mind structure and NSA data as commercial info base source !
Cave te ,U.S.A. !
SYN-DAEMON-MySelf-Question !?
0/1        to -1/0/1       to          ≤ -1/0/≥ 1
Fight Song : the blindes seeing,the deaf hearing,the mute the voice or learning : Body Language
             GESTICULATION ,do not speak ( or write), ( yust) DO IT !        YET
           Margerite -scopie(or other flower/plant) : he/she(/it) loves me,not,loves,not
          In mind : Fort-Pflanzung ( lovely  :-* / Commercial  :-[ reproduction )
         Nun,hinfort with me,tschau,vale bene,mas va !
p.s. II : GESTICULATION and the ' face language ' ,her as female and its as personality : ars avec /sans Ceo/Soul
                          MICROCOSMONAUT* to MACROCOSMOS* ,anybody outthere ? Feedback !?
                                 The Art of Noise/ly - silently(underwriting/underdesigning) -  Communication
Johnsmith
 The drill press I bought came with a small vice. It's handy because when I have a lot of holes to drill, I can
do production runs which makes it much easier for me. One the face that is shown, it will have a 1 inch hole
drilled in about the center.
Then the square dowel will go through it. I'm going to add some more detail to the dowel before I cut it to the
lengths that I need. The reason the dowel is so large is a smaller dowel might bend and that would decrease
how hard it would be hitting the weight wheel.
This coming weekend I should have everything assembled except for the catch and release mechanism. The
slot around the disc is 1/2 inch wide. I might widen the area where the retraction lines will be caught. This
would allow for 2 to be seated next to each other. This is because as one line is being caught another is being
released. Then they wouldn't interfere with each other.
With the 2nd picture, various parts that will make the Kicker Assembly. I had to remove wood from the rectangular
blocks on my table saw and then I had to clean them up. With the triangle, I used a 30º angle. This is because as
it hits a round dowel that will go through the side of the disc, the vertical drop will be about 1/2 of an inch. On my
next build I'll probably use a compound angle. This simply means that the points on each side will move in at about
a 45º angle intersecting with a 15º angle coming up from the bottom. It'll be a nice aesthetic I think.
And the rectangular blocks by the weight wheels will need to be shortened 1/4 of an inch. Then I won't need to use
screws to hold the 2 sides and the axles in place. And the extra weight can only help. It does seem that either next
week or the week after that it'll be known if my last video was actually correct in showing it could work.
I thought I'd add a picture of how the cue and its guide turned out. It was close on the dimensions but then that will
direct most of the movement towards the weight wheel.
time-line
1972 our family,I too, visited Fatima/Ourem/PT https://www.fatima.pt/de/
1984 Munich Fuerstenackerstr. , the house in which we lived by rent condition , landlady A. Ratzinger -Beck ( R.I.P. ,last year Aug.)
        (nephew from a cardinal,later bishop from Rome)
        ground floor she living               second floor above  : to hear inside and outside https://www.youtube.com/watch?v=xw7QcRIEngY
        https://www.youtube.com/watch?v=X4FNqRRl8Ak
        Life Is A Mystery  ;) We,A.R.-Beck and I trusted us each other !   And I heared "dirty laundry" about the R.-baggage ! ??? :( Rating: --
Back to CONSTRUCTIVISM :
the italian B1 class patent application    IT1265815      SELF-PROPELLED SCOOTER or Monopattino Semoventi
         from Aurelio Spoglianti  ,1996 living in   Riolo Terme/Ravenna/ITA
complicated ? confidential ?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19940207&CC=IT&NR=RA920015A1&KC=A1#
Bessler in kind of "scooter wheel" ?!
Skol
OCWL
Johnsmith
 This cover of Jethro Tull's Locomotive Breath is by Sina-Drums of Germany. Between my medical situation (all time loser) and the need
to build a working wheel (can't slow down), I can relate to it. And with Sina-Drums, she's called what I'm building "my wheel". In a sense it is.
Bessler used a different construction technique and might have invented mercury amalgam (think a dentist's silver fillings for your teeth) for
his bearings. He did give a description of what allowed his wheel to rotate on the axle and it was 3 elements.
https://www.youtube.com/watch?v=WW4NP8SgIRc
With what I am working on now, some of the details I'll be adding are just for practice. Once I have the cues mounted,
I'll be able to place the dowel through both discs. Fortunately I have 2 48" T-squares. I'll be able to clamp a block on each
one and then clamp a level to it so they'll be square to the discs. Basically they'll be flat against it. This will be critical
because the kickers on both sides will need to work at the same time. If not then the weight wheel might become jammed
by the uneven movement. After I have it set up I'll post some pictures to show what I mean. That will probably be early
next week.
