Build 2
Started by Johnsmith, December 22, 2021, 08:33:09 PM
kolbacict
Quoteis where liking math actually helps. This is because you have line segment A - Z which is x inches/cm long. Then you can ask
"How can you shorten the distance between points A and Z while the line segment A - Z stays the same length?".
If you use the third dimension. Like distance on the surface of a sphere.
Just like airplanes do when they move between two points, shifting their
trajectory towards the poles. Am I not saying that? ???
Johnsmith
Quote from: kolbacict on January 28, 2022, 06:01:16 AM
I see you are familiar with navigation. If someone travels from Lisbon, Portugal to New York City,
they are both about 40° N latitude.
With the math, the relationship between latitude 40° (sin40) and latitude 60° (sin60) is that
sin 40 is 0.766 while sin 60 is 0.5 or 1.532:1. This means that each degree traveled at 40° latitude is
1.532 times longer than going past the southern tip of Greenland which is at 60° latitude.
This shows that by taking a northern or southern route (depending on which hemisphere you are in) it is
closer to a straight line that traveling laterally around a sphere which is not a straight line. It is the
circumference of the Earth that is traveled.
And with the 2nd image, a straight line from Lisbon to NYC would go through the Earth. At 40° latitude, that
line would go 1000 km or 600 miles into the Earth at that latitude.
Needless to say I find math helps me to understand what I am doing. And with the radius of the Earth being
4000 miles or 6400 kilometers, the relationship to latitudes is a sine function. This means that 2π * r can be
multiplied by sinx to get the same answer as (radius * sinx) * 2π = circumference.
And with the 2nd image, the straight line would go about 1000 km or 600 miles into the Earth.
p.s., Iceland is actually 64° latitude. When I vacationed in Yekaterinburg, Russia, we flew over Iceland at night
(I could see Reykjavik). Reykjavik was lit up and was the only light to be seen so obviously it was an isolated
area which Reykjavic is. That flight went from NYC to Moscow. And Moscow is 55.75° N latitude.
And the island above the de in latitude is Iceland. Reykjavik is its capital.
kolbacict
Would using the third dimension help with your wheel problem?
QuoteIceland is actually 64° latitude. When I vacationed in Yekaterinburg, Russia, we flew over Iceland at night
I envy
Johnsmith
Quote from: kolbacict on January 28, 2022, 01:25:35 PM
I envy
If you look at the 2nd image in the previous post, it shows that following the curve of the Earth is a longer path.
A drum creates a longer path for a line as well.
And since Stefan believes I have killed someone, it is probably best for me not to post in his forum. Such false
claims that people made against me led to my being investigated for killing someone. A simple internet search
would've shown my Facebook page as well as where I live and have lived. Yet everyone trusted a person who wanted my
work or my life ruined.
And it is funny how many Germans believed that person. And to honor what Germans told me, a liar is welcome in Germany.
And Stefan actually posted to me that he hopes I get over having killed my friend. This is James Lindgard;
https://www.presspubs.com/lindgaard-sentenced-to-68-months-for-vehicular-homicide/article_61ec4171-228c-5214-9d66-8cc1fdc14bd5.html
His actual name is Mark James Lindgaard. And I'm not that young but everyone trusted AB Hammer when making such a serious claim. In my
videos, do I look like I would've been 22 when that was reported? This only shows that getting people to trust you has nothing to do with what
you're actually doing.
And yes, the police investigated me for having killed someone because of the stress such accusations bring into someone's life. And this will be
a part of Bessler's legacy if I am successful. People were out to ruin Bessler's life as well for his secret.  Luckily I'll be able to do science after this.
What needs to be understood is that people who live in Richmond, Kentucky, USA believe I killed someone. I will need to clear my name. Of
course, AB Hammer can say that as a Christian he saw the opportunity to redeem a sinner because that's what Christians do. And that he was wrong,
that didn't affect his life.
@kolbacict, the 2 pictures show a bearing hanging from the disc from its fulcrum and then when it swings around the disc. In the 1st image, look near
the bottom of the picture by the T square (straight edge). In the 2nd image, I put tape on the bearing to make it easier to see. The difference in how
far the bearing is from the disc is the same distance the weight wheel moves up the arm it is on.
Basically when the wheel rotates, it has the same effect as the drum rotating. The line is wrapping around the Bessler's external drum.
Around the firmly placed horizontal axis is a rotating disc (low or narrow cylinder) which resembles a grindstone. This disc can be called the principle piece of my machine. Accordingly, this wheel consists of an external wheel (or drum) for raising weights which is covered with stretched linen.
https://besslerwheel.com/writings/das_triumphans.html
activ25
Your story remembered mine. Believe in what you are doing.
