New electromagnet configuration 4 times out verses in
Started by jimbo, January 19, 2022, 01:37:22 AM
captainpecan
Quote from: citfta on January 29, 2022, 07:47:54 AM
It is obvious that the magnets are doing something to the transformer provided the video isn't fake.  But that can only happen if the transformer is being pulsed with DC.  If he is using AC to power the transformer then the magnets should have the same effect no matter which way they are turned.
Something interesting about what you just said, is quite some time ago, I made a very simple invertor circuit that was a 2 mosfet oscilator, an inductor and transformer. I was just using it to run an 8 watt led house light bulb on about 1.5 watts power to play around. When I attached a permanent magnet to the transformer, the bulb got brighter, and the current draw dropped by 100ma. That transformer was getting pulsed DC from the oscillator, but it was to a center tapped winding. Therefor from the transformers perspective, it was basically an AC current going in. So even though what you said makes perfect sense, I saw something back then that tells me something else is going on there also. Maybe it makes the core flux "more springy" per say? But you would think at the same time one polarity was more, the other should be less? So I get exactly what you say. Wasn't anything major and I just thought it was cool to get brighter light for less amperage simply by sticking a magnet to it. But I saw something and in my opinion, it was AC also. Just made me think about that old experiment and now I'm curious why I saw what I did when it was AC?
jimbo
I got this notion of trying a motor casing for a three phase motor .they have like ??? 6 ??? Windings I think and there imbedded in the iron ring .if I was to connect a positive pluse to a winding and find one or more of the other windings giving off power like transformer might then add the magnets ? Moving them around to find the best spot .this might replace the rotor and if it did advance the power then by how much and did the rest put out too ?.or might I need to add more magnets or input more coils ? .I'd like to see this transformer set up cascaded into more transformers .and more magnets . this reminds me of a triode tube or gate .can this be done to a air coil ?. Yes bifiler would be better .I've done a bedini solid state ssg coil and it strips lead sulfide off in 4 days running around 500,000 hz I found out its not the h wave so much as the repeated pounding of the pluse .I saw a PDF of a setup using under 12 volts and high frequency doing the same thing its called defoliation .this is interesting for possible desulfating while using the batteries . I might be able to find the right voltage and amps for each different coil with a varact and a big diode.tunning to minimum release and most energy transfer just below the iron saturation point . good hunting .
jimbo
This topic has got me thinking about older technology like on the Patrick Kelly PDF there's several old devices pretty close to this but with out the magnets .like a French one I saw that had multiple iron cores in a circle raped in copper wires cascading around ..did they leave out this inter magnet part for the patent to hide this for protection ?.would one advance the next then that advance the next and so on each adding ?.
captainpecan
Some of your thoughts remind me of concepts behind the workings of Tom Beardens MEG and many different off shoot concepts I've seen people work with. I haven't done much work in those fields but I always kind of wanted to. There may be some more great little concepts from others work in that area that may help on these projects. Just thinking out loud kind of.
jimbo
Tom beardens MEG didn't work it couldn't be tuned .so he says .he needed a army of engineers to figure out the tunning and it was going to cost to much . I guess not may know that because I hear it a lot. Rick has done a lot of investigation on don Smith  technology and has succeeded in mass resonance in like over 100 coils ? At once and the next step is doing it at hivoltage .he seems to have a fear of hivoltage rf.but with out the hivoltage you get zip noda.its coming out this summer I think .if he does it at all.it might put a bulls eye on his back.like bedini and his brother and  don smith ect ..
