Converting mass responsible for Dark Matter into Energy
Started by MGsid, February 23, 2022, 05:30:56 AM
panyuming
MGsid,Thanks for the guidance!
The dimensions below may be smooth. Outer ring diameter = 516mm. Total length approx=7191mm
I also want to ask: which of the various primary coils is better and what method can be used to measure them?
MGsid
Your welcome! I appreciate that you want to build this device!
QuoteI also want to ask: which of the various primary coils is better and what method can be used to measure them?
Both coils should give similar results, but to keep it simple, stay with 6/5 harmonic with 8 rings.
I'm not sure what you mean by "method to measure them". If you refer to how much energy it will produce, then you can use formula for energy in the center of spiral from PDF file I've attached in second post.
Hope this answers your question.
QuoteThe dimensions below may be smooth. Outer ring diameter = 516mm. Total length approx=7191mm
This coil should be fine. It looks good and has 6/5 harmonic proportions, so should be good.
MGsid
@panyuming
Post some pictures if you make this coil. I'm curious how it turned out!
panyuming
Quote from: MGsid on September 22, 2023, 04:36:28 AM
@panyuming
Oh, I haven't done it yet, I'm afraid I'll be the same as I used to do Tesla coils, and I won't see the effect of OU.
MGsid
@panyuming
It will work! There will be effect of OU because you will have higher frequency in the center. Regular tesla coil secondary is tuned to primary circuit frequency, and with this coil you will have primary * 1.2^8 Hz. This higher frequency in the center will give you OU effect.
