rakarskiy
Quote from: kolbacict on December 14, 2022, 05:40:16 AM
Уважаемый Ракарский,смотрите что мне тут сегодня подкинули...
The other ones can too... :)
Therefore, a problem arises as to how the electromagnetic system of an electromagnetic machine in which the phase wire is laid in a groove works. Useless work, as for a designer.
And also an asynchronous generator, where the rotor is a "squirrel cage", in no way cancels the parameter of the electromagnetic moment of the generator.
But Holcomb's double squirrel cage generator has COP-4
Quote from: Cadman on December 14, 2022, 08:04:57 AM
This is why the inline generators are being allowed by the government, or should I say the people that control the government. The reason is the power companies will be allowed to use this tech to increase their profits. They will install it in their distribution stations ahead of the consumer. Their generation costs will fall drastically, but we, the end user, will still pay the higher prices.
If you are wealthy, you may be able to have one at your residence or business too. But only if you can afford it. I expect a batch of legislation or regulation laws will be created to throw obstacles into the path of private use too.
Of course this is just my opinion.
I think such devices are already in operation, they produce energy that is sold to the consumer at market prices. For example "Earth engine" from the USA.
ramset
"Earth engine" a very bad example to use
"Issues" which need not be discussed here  .. can be found
On Google search!
Unless something has changed recently?
One question which I am a bit afraid to ask ( my ignorance in these things)
3phase industrial users if they we're unaware of power factor correction technology
What would a typical savings look like to that "unaware user" once he installed a typical correction unit ( not at all referring to unit being discussed in thread subject  !
Would a typical power factor unit save a heavy 3phase user
"Quote "
It's saving incredible amount
"quote "1/3 rd of previous bills "?
Also
Still trying to qualify some customer feedback I have heard through grapevine
Please no "he said she said" on topic claimant ( Stefan's liability is key issue here)
This is just a question on typical heavy user with no industry standard power factor correction
Before and after savings?
Percentage wise ?
I know it's hard question..however?
Perspective is good to know !
Thanks Grandma
rakarskiy
PFC (Power Factor Correction, power factor correction, reactive power compensation) is a characteristic attribute for switching power supplies, indicating the presence of a certain circuit in them, which allows you to approximate the useful and received power.
It is one thing to produce, another thing is to protect the generation equipment from a reverse reactive power pulse. If this is not provided for, a serious buyer cannot be found.
"Earth engine" was developed for remote areas. Why don't you like the example? Very good, free energy is sold for money as carbon footprint energy. That's where it happens, they won't tell us exactly
bistander
Quote from: ramset on December 14, 2022, 10:46:24 AM
On Google search!
"Quote "
Also
Percentage wise ?
Hello ramset,
Below are a couple explanatory sites. The third has actual calculator. My understanding is that cost saving is handled via contract between user and utility.
bi
https://hillhousepower.com/power-factor-correction?gclid=CjwKCAiAheacBhB8EiwAItVO2xnzUYfuFyP8oJ_Vw5ZQM1OQO5gZSS9OFUFwePXkjKz8cM6hv9iE1hoCDHIQAvD_BwE
_______
https://en.m.wikipedia.org/wiki/Synchronous_condenser
_______
www.CDE.comSavings and Application Guide for Power Factor Correction and Harmonic Solutions
________
edit: third link doesn't work. Copy entire line and paste into Google.
onepower
Hey Chet
QuotePlease no "he said she said" on topic claimant ( Stefan's liability is key issue here)
I used to design and build my own AC induction motors/generators and stand alone island mode systems.
Simply put an inductance(L) acts like a mass and a capacitance(C) like a spring in LC systems. So an induction motor/generator is like a LC oscillator in itself within the larger grid LC oscillator. When we speak of power factor correction were talking about adding more C to compensate for an excess of L in the system.
It's not actually the motor/generator causing the issue but the self-inductance of the stator in relationship to the induced field of the loaded rotor. Excess loading/lack of stator capacitance causes increased slippage ergo increased induction on the rotor and heating losses. Simply put the stator/rotor starts acting like a space heater. In island mode systems a lack of C to properly induce the rotor with enough reactive power to lock the stator/rotor fields can cause excess slippage or even a loss of rotor induction all together.
So by adding more C to correct the LC/ power factor we can reduce the losses. Were basically switching in more or less C to compensate for a changing L. Losses can run up to 20% because the motor basically becomes a resistance heater and I have even seen motors start on fire.
We could also think of it this way, your house is separated from the grid by a big step down transformer. So the transformer and all the other loads have a combined L and C. In effect it's a big LC oscillator and when the L or C are out of sync it starts dissipating some of the energy as heat. The energy doesn't just disappear it always shows up as heat somewhere in the system.
AC
