listener192
Using solid state switching would remove the brush/speed issues.
This setup is using a steel armature and steel rotor, so by your own reasoning lenz would still apply and its obvious that output power remains much  lower than input power.
So for the most part it is behaving, as I would expect Holcombs 16 salient pole rotor to behave.. much less than 100% efficient.
I have seen this condition before where you reach a switching speed where the coil on period versus the coil inductance  is just sufficent to reach maximum coil current limited by supply voltage and coil resistance. As you approach this point input current drops and output current and voltage into the load increases.
Normally a further increase in switching speed results in a drop in output voltage and current. At no point does anything remarkable happen.
Ufopolitics
Quote from: listener192 on December 30, 2022, 03:07:10 PM
You can't judge Holcomb's system based on my lousy setup ande testing!!...I know where to improve, I still have many more tests to make...and other setup to build and test.
Plus I got a 4 ch scope and two amp probe clamps...so, yes, tests would be more accurate.
Hey L192, man, no matter what, you (as many here) would always see a half full glass as "a half empty glass"...while I, will always look at it as "a half full glass"...
Have everyone a very Happy New Year!!
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
SolarLab
A quick one before a long many or two - Happy Hour!
BACK EMF (Motor) & MAGNETIC DRAG (Generator)
https://www.youtube.com/watch?v=Ao4B_kYeG10
NOTE:
# 1. "after some time - repeated..." (dv/dt, di/dt, Tau) (Inductance, B-H).
#2.  But in the HES Generator there is NO mechanical input to oppose!
#3. And, as we know - there is NO constant Magnetic Field in the HES.
      It is switched On/Off. In an apparent rotating manner.
SL
P.S. I won't phone for Bail before 11:00 AM...  :)
SolarLab
After a good Beer Reset:
' Forgot to add an important part - #1b. '
NOTE:
#1a. "after some time" - repeated... (dv/dt, di/dt, Tau) (Inductance, B-H).
#1b. "a current carrying conductor..."
#2.  But in the HES Generator, there is NO mechanical input to oppose!
OK, now lets get back to "Reset #2!"     Happy New Year!  :P
SL
Just for comparison, consider a different attempt to explain this stuff:
https://www.youtube.com/watch?v=5XcWJa9JBuY
Now you can see why things can get confused real quick!
(Trying to hard to be technical before the basics are understood?)
A Lesson...
and, #4. As you can see, HES has very little in common with a conventional
              Motor or Generator in both operation and theory. Think differently!
Plus - HES is a Generator only, with no moving physical parts!
Dog-One
Quote from: SolarLab on December 31, 2022, 08:00:06 PM
A Lesson...
I still feel like we are looking at two motor/generators coupled together in a single black box.  We see an electrical input and an electrical output, but we don't see the center coupling, not directly.  That center part is where the magic is, hidden in the magnetic forces.  I wish rakarskiy would just tell us in a paragraph or two.  Even better if he could show us a simple demonstration.  I'd really like to experience that "Oh!  I get it now!" moment.
