audio amplifier as a power generator (instruction)
Started by dxer_87, September 21, 2022, 03:56:14 PM
Pan yuming
dxer_87
For some amplifiers this schematic may even work.
1. With 1 ohm transformer the amplifier may overheat. There are many 12V transformers that have 1.8 ohm or more, just search.
2. You show noplis goes into gnd. This is mistake and would make a short circuit. If you would even take only signal from phase and wound around the main caps this may help. I mean in noplis to 'go through'.
3. Neutral needs to be grounded. Only one output of transformer is suitable. Put a normal 15W max! Lightbulb and connect your grounding to different ends and find is there any voltage raise(more light). Then ground this side. Set the voltage on potentiometer to 245-248V unloaded. You may try with my extra grounding.
4. Sometimes, especially if booster is used to put pcb gnd into vibration you may connect tops of the caps(the alu cover) with mass. This is another trick(captret effect) i used to use back in the day.
5. Your schematic is not safe for rcd. Though this breaks kirchhoff law and You may see your meter consuming half of the power ;). Just install it to nearest wall socket to power meter (5 metres or lower).
To be safe for rcd you need to use dual channel start switch and 'believe' in your caps for a second.
Greetings!
Dxer.
I know this worked for some of You! :-)) Thanks for the donations. I'll try to contact to Pan Yuming, correct the schematic and publish. Ask here any question!!! If you manage to do one paulos gen. , Do more for your neighbours to save this technology.
dxer_87
how to make Noplis correctly :). a very important wire :D.
Dxer.
dxer_87
Here is the new version of instruction :) Save it and print. Give it to friends that doesn't have internet.
Dxer.
dxer_87
I want to put my thanks to all that donate. Here is the last version of instruction, now without bank account. I've added also alternative schematics.
Will be great if You have achieved to build several of such. It's not a secret anymore :).
Dxer.
