hwvc.org capillary power
Started by Tarsier_79, October 01, 2022, 05:18:19 PM
Tarsier_79
MagnaProp
Thanks for sharing your device.
I am a little confused as to how it works.
(1_StickMovesUp.jpg) = Capillary part causes stick to moves up. I think I understand this part.
(2_Clockwise.jpg) = Capillary is on the left side of image and stick moves up, which causes clockwise rotation. I think I understand this part.
(3_Clockwise.jpg) = The capillary is now on the right side of image and the stick is shown moving down it causing clockwise rotation. I don't understand this part. I would expect the stick to move up the right side capillary causing a counter clockwise rotation.
Tarsier_79
It is not my device. I have not seen one IRL. I do not know if it is a true working device. If it does work, I imagine it will have very limited power.
The capillary is always only on the left. The author has drawn the meniscus created by the ring on the right.
This capillary lift is the part that interests me. From what I understand, the open truncated cone's opening is only 5mm.
Sergh
This is good.
Capillary effect - van der Waals force - Casimir effect - vacuum quantum energy.
Vacuum quantum energy - "Zero-Point energy" -  greatest amount of energy in a cubic centimeter.
To obtain a large amount of energy, it is probably necessary to use billions of nanoscale capillaries in spontaneously structured substances.
It will be better to convert nanoscale mechanical energy into chemical energy, for example, into energy for chemical reduction reactions. (RedOx reactions)
The total amount of solar energy absorbed by the atmosphere, land surface and ocean is approximately 3 850 000 exajoules (EJ) per year:
https://en.wikipedia.org/wiki/Solar_energy
1 exajoule = 10 in 18th joules.
1 cubic centimeter of vacuum theoretically contains 1 0000000 0000000000 0000000000 0000000000 0000000000 0000000000 0000000000 0000000000 0000000000 exajoules .    :o
it is quite possible to evaporate all oceans with such gigantic energy.
https://www.youtube.com/watch?v=n6jAOV7bZ3Y
https://www.youtube.com/watch?v=Rh898Yr5YZ8
skywatcher
