Sucahyo Stingo Oscillator Experiments
Started by SkyWatcher123, March 13, 2023, 03:27:55 PM
SkyWatcher123
Hi panyuming, yes it works well enough.
I'm testing a new coil setup.
This coil is three 24awg. magnet wires, wound trifilar at 1.4 ohms.
This coil and former, is placed on a ferrite flyback c-core, from television.
The efficiency is better, using 2 watts less and giving more output current.
The frequency is much lower, with the ferrite core, though the 2 halves of
the core, are not connecting, probably a 1/4" gap.
Experiments shall continue.
All comments welcome
peace love light
panyuming
Quote from: SkyWatcher123 on March 16, 2023, 11:57:40 PM
peace love light
I'm going to put this thread of yours and other threads that charge the battery with pulses.
Classified as a Bedini device.
Previously I studied Bedini device.
See that many points are included:
1. The effect of rotating wheel magnet passing through the coil.
2. Multi-stranded wire and 7 transistor driven coils.
3. The speed of the reverse peak voltage rise when the coil is cut-off.
4. Charge the battery with the reverse peak voltage of the coil.
5. Charge the capacitor with the coil reverse peak voltage.
6. Charge the battery with capacitor discharge.
I can't guess which of them causes the OU effect.
I have only experimented with charging lead-acid batteries with coil fast reverse peak voltage.
No OU phenomenon was measured.
Because I heard that fast pulses can elicit 'radiant energy'.
I spark the lead-acid battery directly.
Think this is the fastest pulse I get along with.
The OU phenomenon was also not measured.
Learn to copy someone else's device,
It may be only a little bit closer to success.
I heard a story from the 1940s.
There is a company that can make very good large lenses.
In addition, corporatization buys their secrets at a high price.
Inform after the transaction: non-stop stirring.
So I envy your hard experimenters who get the OU effect.
SkyWatcher123
Hi all, been testing this oscillator circuit and it is working quite well.
I changed the coil/core, am now using multiple stacked ferrite toroids, 5-3/4" long
by 1-1/4" diameter core. Using 18awg. magnet wire, 2 layers of bifilar wound.
Each layer is wired in series and each coil layer is in series with each other,
800 milliohms total coil resistance.
This coil/core is the best performer and efficiency so far, it has a fair bit of weight to it.
The battery is rising in voltage discharge curve, meaning, as a certain discharge voltage
is reached, the discharge time duration is incrementally rising.
The battery is being charged to 15.60 volts.
Other charging time data is still being gathered.
The one who shared this circuit, claimed the batteries charged 6 times faster with this circuit
so that is something being observed also.
The circuit also gives 1% on time for any frequency.
peace love light  :)
sm0ky2
Quote from: panyuming on March 17, 2023, 05:06:50 AM
Yes, common academia accredits Bengt Wahlqvist, but it was in fact
John Bedini that invented the pulse charger, more than 40 yrs ago.
As per your list of qualities:
None of those are the secret sauce.
If you truly want to understand:
Place a child on a swing and push them
What makes Bedini's devices do what they do is sympathetic harmony.
The pulses are timed to the rpm. This is key
small impulse to keep the momentum going
energy generation, based on momentum
NOT applied force!
Back EMF is fighting the momentum
not fighting the impluse
This is MUCH different than a direct drive motor.
Wherein the back EMF is constantly fighting the driving force.
Bedini's machines are an electrical analogy to William Skinners gravity drive.
The main difference being the potential well that is drawn from.
sm0ky2
Think of a Whirly-go-round
With many children on it.
And one small child with limited energy potential
getting that wheel up to speed with his tiny feet.
Now this child does not, by himself, have the potential to push all of those children hard enough to increase their velocity the way the wheel does.
But stop the wheel suddenly, and all of those children, and all of their perspective masses go flying in every direction.
If the child didnt have it in him, where then did all that energy come from?
