The Secrets Of Back EMF
Started by joellagace, March 19, 2023, 05:51:24 PM
dsquared18
Looking forward to see where you're taking this Joel. It's very intriguing.
Keep up the good work!
D2
bistander
Here you go. And the attachment to my prior post defines it well. It sure does not sound like what you go on about. Do you have a well written definition, description and analysis of your theory?
bi
{edit}
I read this:  https://overunity.com/19420/self-powered-back-emf-generator/msg575259/#msg575259
So my issue is one of your use of terminology, like "back EMF". There are other examples. I see where this has been mentioned by other members to you. I don't discourage you, just don't see secrets of or generation of "back EMF" in what you describe. You should call it something else in my opinion. Carry on and good luck.
(Perhaps name it after yourself)
joellagace
The focus of my topic is how to take advantage of back emf and use it as a feedback loop with the help of a dual coil system. I explain this kind of feedback loop. This is the mechanism I talk about when refer to "secret" If you would have watched the video as you would understand why I call it as such, I could have used any other word to describe "rare" as I have not found ample info regarding this kind of a loop with back emf systems. Most people stick with external triggers that are only one shot events. My methods offer alternative, Is self sustainable and does not "warp" the terminally or working principles of back emf whatsoever. The science and physics that I use are sound and well founded. Part of science is being able to take some existing ideas and well founded concepts and make them work together to produce different and beneficial effects.
panyuming
Many thanks to Joellagace for sharing his experience of charging batteries with capacitor discharge.
I probably know what the problem is in the video.
Inductance, not a brief 'trigger', can produce a relatively high back EMF.
As described in Bistander's profile.
The BEMF generated when the transistor is opened is determined by the last stored energy in the inductor.
The energy in the inductor is obtained by integrating the inductor current during the transistor's on-turn-on.
A short 'trigger' can only produce a shorter BEMF.
These are energy issues, not just voltage issues.
Energy is the product of three parameters: voltage, current, and time.
And the current in the inductor varies over time (the simplest DC system).
Experiments with two coils will show the actual effect.
Thank you
bistander
Quote from: panyuming on March 20, 2023, 05:27:05 AM
Thank you
Thank you panyuming. That's the problem. The terminology is being used incorrectly such that it appears to make no sense at all. It's like saying to make a salad using voltage. WTH?
Quote from: joellagace on March 20, 2023, 03:39:51 AM"warp" the terminally or working principles of back emf whatsoever
What does this mean. Show the "well founded principle".
So please, go do whatever. I'll just standby and not interfere.
bi
