ZERG generator nullifies EMF with field, "doubles input efficiency"
Started by Cloxxki, April 13, 2023, 06:07:26 PM
i_ron
I am a visual person and much prefer pictures and well notated graphics.
So once I figured out that the strange blob over the coil was not a magnet
but the inventors way of showing the Lenz component the light came on.
This is not a variable reluctance device such as the Hildenbrand but closer
akin to Thane Heins where a more convenient path is provided for the
Lenz component and even Naudin's  delayed Lenz.
How it works:  The passing magnet imparts it's flux to the frame, coil core
and shunt. If a load is placed on the coil then the Lenz component
will take the easiest shortest route through the shunt. Simple as that.
Ron
bistander
Quote from: i_ron on April 15, 2023, 11:37:07 AM
Ron
Hi Ron,
Check the cut/paste of the claims which I posted. It specifically says it is a PM. Here's the part for easy viewing:
Quote*
a magnetic field conduit made up of at least one piece of permeable material attached to the outside of the said coil and permanent magnet ;
bi
i_ron
Quote from: bistander on April 15, 2023, 12:17:28 PM
Hi Ron,
bi
Yes, you are correct, 400 is a magnet, thanks for the correction.
Ron
bistander
You're welcome Ron.
Also, regarding PMs, notice their quote:
ZERG, a 150kw AC magnet-less generator was successfully tested and verified by third party Intertek, a company that started with Thomas Edison.
Besides the famous name drop, the magnet-less feature excludes that machine from patent claims.... no IP protection there.
bi
i_ron
I threw together a small POC.
There is no additional draw when loading or shorting.
However the output is so slight, just over 8 volts no load and 1 volt over a 300 ohm load resistor that that is no surprise.
you can see item number 400 in this shot, 0.9 volt AC no item 400 and 1 volt AC with item 400.
Fair no load scope shot, reducing to a nice sine wave under load.
So the question is how to get more output? I have the coil core and the shunt the same dimensions, bad? The shunt should be way smaller?
Ron
