Re: Self Looped Cap Dump Bedini Motor
Started by Dave Wing, September 01, 2023, 08:24:58 AM
Dave Wing
A video showing the waveform's counter clockwise produces a more negative waveform vs a clockwise which produces a more positive waveform.
https://youtu.be/EvvkbkePDwg?si=eiMpvnYM0jHulMBQ
Dave Wing
tinman
Quoteauthor=Dave Wing link=topic=19537.msg582002#msg582002 date=1693854332
QuoteI have seen all those YouTube channels over the years, however I don't think I ever watched this one particular video https://youtu.be/hvf9Uo7UVx0?si=ffgltO6zmKJ7FGt3 it is a nice piece of work Brad, very interesting. How far did you get with it?
Lets just say it is one of the most efficient LED drivers you will ever see.
Re: #92
I couple an average 90% conversion efficiency electric motor with an average 90% efficient electric generator and get a total system
η  spoken Eta
about 0,9 x 0,9 = 0,81 ,means : 81% efficiency
                    C.O.P. IS NOT efficiency !
An heat pump with C.O.P. 3x has as machine Eta :
1 -(1/3) = 0,66 , means 66% net efficiency
Question : which can be the motor-generator C.O.P.,min. to max. ?
Electric motors as electric generators makes part from thermodynamic machines ergo to observate :
https://www.mecholic.com/2015/10/what-is-exergy-and-anergy.html?m=1
wmbr
OCWL
p.s.: Eta-max  and the middle stone in the game tic-tac-toe
        a motor-generator couple with a C.O.P. 100x has an Eta :
        1- (1/100) = 0,99 ,means  99 % efficiency
       a motor-generator couple with C.O.P. 1000x
       1-(1/1000) = 0,999 ,means 99,9% efficiency
      Eta ≥ 1 NEVER  to reach !
     Eta =1 ~ tictactoe M-point,ever fixed ,unreachable
Dave Wing
Quote from: Dave Wing on September 04, 2023, 03:28:01 PM
I cannot speak for anyone but myself, it has been a long process of learning, spinning your wheels and then learning, I have been researching free energy and purchased Energy From The Vacuum by Thomas Bearden in August 2005. I was on the Bedini Yahoo groups, prior to the forums you see now. One thing I discovered is it takes an extreme amount to work to find those needles in the hay stack. Those needles are hidden under piles of information, misinformation, disinformation, you name it. I am so surprised to this day that the free energy community does not have an open source path to construct a basic free energy machine that produces mechanical energy by self powering itself. It's shameful, but understandable why we do not have build instructions of such a device in the public domain that anyone can build, by looking it up on line.
Enough said...
Now I believe the whole point of the SG is not to charge a secondary battery bank, the purpose of the SG is to try and teach the experimenter to advance his understanding of what the machine is doing and make the necessary changes to maximize the recovery section and send that as feed back to the primary circuit so the machine can power itself. To me that is how experimenters should be thinking ((( feed back))) it can be done with an isolated winding. Remember the SG with the inductive trigger winding is a 1:1 transformer as shown by John. Trigger the SG with external trigger mechanism, small inductive coil, hall switch, opto, etc. and make sure you have a separate winding for transformer action. People need to be thinking of feed back loops, Energy can neither be created or destroyed, but can it be recycled as feed back to the front end powering the machine! That is one aspect and or area that needs to be strongly focused on by the free energy community.
Dave Wing
The Bedini SG is... well I'll let John Describe it.
seychelles
SO TRUE LANCA. I HAVE ALWAYS SAID THAT THE MOTHER AND FATHER OF OVER UNITY IS EFFICIENCY
AND ONE NEEDS TO KNOW WHERE THE ENERGY IS COMING FROM.
