Re: Self Looped Cap Dump Bedini Motor
Started by Dave Wing, September 01, 2023, 08:24:58 AM
Dave Wing
So the million dollar question is...
When looking at the images above which induced portion of the waveform created from the North Pole passing the core of the coil produces an induced voltage (EMF) in the same direction as the applied voltage of the primary battery?
Again...
Is it the positive or negative portion of the North Pole asymmetrical waveform?
What happens if you reduce the magnitude of the negative portion of the waveform, so that the EMF is more positive than negative? As the image below shows.
Image below screen shots from this video... https://youtu.be/p-btQuWH5XQ?si=KQ09EN_Da0W7nejm
Dave Wing
Chat GPT describes the result of CEMF inversion to aid the applied voltage of the primary battery.
Dave Wing
Dave Wing
A few posts by erfinder regarding the image posted by user Kiril_Kirilov.
Dave Wing
Posts based upon the triplet of inductors and how they produce the asymmetrical waveform, and how forgiving they are as low drag generators that use Lenz law for us and not against us as CEMF.
