The most efficient machine ever built
Started by innovation_station, February 10, 2007, 09:04:11 PM
innovation_station
hello wer and all
#3 is a waste of time for now it is more of a high volume lower pressure turbine right now im in to the speed
i recomend if you want to build and display your pics here you build the 1 in the picture below because it is cheep and easy to build and test with i used a grinder axel from tsc 2 cost 35 bucks also 2 9 buck bearings from tsc 1 skill saw blade 24 tooth  7.75" 5 bucks at canadian tire and 2 bell bar weights cast iorn from wall mart total weight around 21 lbs @ 1500 psi it reached speeds of 15 000 rpm  i am half finished building my generator a lot of work
is
pictures soon
innovation_station
as i said  soon here they are im only half finished.  thease are built from the drawings i posted been working long and hard on this if this dosent work its on to somthing else
is
wont know for sure till u try
innovation_station
hello wer and all
here is a drawing of prototype #4 it is an 8" circle all is perfectly spaced and ballanced this drawing is all you need to build #4 just print it off and use it as a pattern drill 4 .5 " holes in the cast iorn weights and and the skilsaw blade and bolt it all togather and spin it that is all i would like to see any pictures of any one who is also building this turbine so post them please!! i still see no reason why this will not work it spins that is all it needs to do and it spins fast my generator is getting closer to being finished but still much work to do on it my latest pic of the generator is below as well
is
innovation_station
hello all
it is a slow and long process for me but i will get there been working long days so verry little time on projects right now but im hoping next week will bring about a finished generator that i can hook up to my turbine and see what happins i would expect higher voltages from this unit also i was looking in walmart and it seams they have somthing neat for use with this turbine generator it is a car audio cap with read out cost is 50 cdn for 1 i was thinking of buying some and hooking them up to my coils anyone have any ideas on how many coils i could hook to 1 cap beacuse if i bought 1 for each pair of coils it could get kinda expencive but if i could hook up 3 pairs of coils to 1 cap then cost is much lower each coil should produce 20 -30 volts x 2 coils per mag group so 40 - 60 volts per pair of coils and there 15 pairs in total
dont know verry much about caps
any ideas on the caps  let me know
ist
innovation_station
hello all
i would like to welcome all to the basic model of the
FISLINGER POWER GENERATION SYSTEM
basicly what you all have seen is the simple version i have been playing around with many ideas in my head over the last 6 weeks for this system and i have come to the conclusion that it needs to be more efficient for all of you to beleave it is and will be overunity
so what i have decided to do after i compleat this current build is to make it better to do that this is what i will do i will lower input power by simply adding a gas powered presure washer maybe a 5 hp or so 2500 psi there bouts now it will not run on gas it will run on hydgron and the machine will have in it a hydgron on demand fuel cell built in to it 1 side of the turbine will have the generator i have almost finished building and the other side of the turbine will have  1 half of the filsinger redesinged n machine generator or simply a faraday disc generator that will then create the power for the fuel cell to make it operate and the other side will be only used for output ac power at high speed
now you all will say how can that ever work?
my answer is i think it will work but i will have to build it and see
the reason i say that is cuz the efficiency of the gas engine is poor 22 percent or there bouts but what is the efficiency of the fuel cell? also the pump is nowhere near unity so with all of those losses how can it be overunity the answer is as i beleave right now speed will make it overunity and the laque of friction will help it
for those of u that think that the turbine is verry inefficient how about this maybe im putting too much water in to it mabe it only needs 1L / min so if it did that alone will lower my in put power by a large amount i beleave this turbine runs on pressure  the more pressue the faster the spinn
the innovation station team!!
we are all going to find out soon
i will be making drawings of the second version of the
FILSINGER POWER GENERATION SYSTEM
in the next month  and be posting  the drawings for all to see
