rotoverter for power generation
Started by dan, May 02, 2005, 03:57:50 PM
esaruoho
 congrats for 2nd place in applied mechanics california state 2008 science fair
hi.. just found this, some of you might find it interesting:
CALIFORNIA STATE SCIENCE FAIR - 2008 PROJECT SUMMARY
Name(s) Austin Adee; Alex Thomas
Project Number S0801
Project Title: Rotoverter
Abstract
Objectives/Goals
The objective of our project is to see if electricity can be generated more efficiently than onventional methods. We hypothesize that using two three-phase motors, in a setup a "Rotoverter" electric energy can be generated more efficiently than conventional methods.
Methods/Materials
Materials: A steel U beams, copper wire, capacitors, switches, power meters, two AC three phase squirrel cage motors, Plexiglas, transformers, full wave bridge rectifiers, an inverter, and epoxy are used in our experiment.
Methods: To build our setup; weld the steel U beam in a rectangular configuration; open the electric
motors, and clean the bearings of grease; reverse the casing of one of the two electric motors, and
assemble them back together; wire the motors so that one is an alternator and the other a motor; wire the switches in series to the capacitors, which are parallel to each other; and wire the capacitor banks to motor and alternator.
Results
We successfully found an alternative way to generate electric energy more efficiently than conventional means. In the process of doing this, we generated more reactive power than is consumed. Reactive power can be described as energy that does net value of no work. Achieving a greater amount of reactive power than true power is not a new concept and is accomplished very easily. What's different about the Rotoverter is that we can extract some of this power which is considered imposable by definition. We are not sure how the Rotoverter works, but only that it does produce large amounts of reactive energy that can be extracted on a small scale. There are two probable solutions around this; either get a resistive load to match our resonating output, which in our case would be a 4.5kw light bulb; or get an inductive load such as a transformer, that does not break the resonance of the alternator.
Conclusions/Discussion
As of this moment, we have only produced reactive power, but at a much greater amount than real power
consumed. We have not yet experimented with the two possible solutions mentioned before because of the
lack of materials. Further experimentation may reveal that the reactive power can be extracted.
from http://www.usc.edu/CSSF/Current/Projects/S0801.pdf
so here's another "yep, we got some reactive power running in our rotoverter circuit - and it should eventually be extracted" type thing.
what are your thoughts on this, please?
valdimlajr
Guys, Who says rotoverter does'nt work? I did it tried myself. I used 2 Australian made 7.5 hp motors as prime mover and generator respectively and I got output 7 times the input of 200 watts. Better try it yourself to disprove Hector's discovery. Don't be an asshole arguing without doing it yourself. I am a mechanical engineer and I did it ran infront of some engineers here in the Philippines. People here are the "see it to believe it" type like you. I'm betting my balls on it!
VAL
esaruoho
Quote from: valdimlajr on December 06, 2008, 05:51:24 AM
was that 7 times output the "out of phase" virtual current (was it VAR that they called it?) that some have managed to get circulating inside the setup, or did you extract it - and with which extraction circuit, please?
i think theres certain people who doubt anything related to the rotoverter, who would really appreciate some details on this whole thing. its nice to see at least someone on overunity.com actually doing something related to the rotoverter. btw,there was a more active discussion going in the rotoverter thread over at http://energeticforum.com/renewable-energy/
esaruoho
hi, this is something that koneheadx created: and the video descriptions:
http://uk.youtube.com/watch?v=RzO_lzgfoKM
This a step by step "hands-on" AC motor rotovertor conversion demonstration.
I eventually got this motor to run at 180 milliamps at 120Vac with no load on shaft with a 9uf run cap.
IN NUTSHELL:
1) Hook 3ph AC motor up to its HV 460V circuit shown on its label. (they usually use the 460V circuit with these 3ph type of AC motors in heavy industry and factories)
2) Connect AC power feed to only 2 of the 3phases, so that the AC power feed lines connect to line 1 and line 2 coming from the motor.
3) Connect run caps and start caps between line 2 and line 3 coming from the motor..
Note: Line 2 coming from motor shares a connection with one of the power-feed lines, and also one side of the AC run and start caps.
4) Adjsut run cap UF value to get lowest draw first at idle, and also when the shaft turns a load too.
For beginners, run the rotovertor simply on single phase 120VAC grid power (or 240V if that is what you have in your country)
Later on, run these on a DC to AC INVERTOR! Now you will then be running this motor on batteries - golf cart batteries are the norm, as they are a type of battery that can be discharged and charged everyday for 5years before they go bad - while regular car batteries can only do a few dozen discharge-charge cycles before they are no good.
For very advanced work with a rotovertor motor, use pulse width, voltage and freqeuncy adjsutment so you can really nail a super effecient rpm, voltage and power level for the particular load the motor is turning.
With these three modificationss to the motor (actually inside the invertor running it), you will most probably be able to acheive a self-running unit if you also have a very effecient no-lug type of generator on the shaft too.
go to my site:
http://www.geocities.com/koneheadx/
look at link #16 for a rotovertor spinning a Bill Muller design of dynamo/generator
Also look at "circuit diagrams" link on my site too for the basic rotovertor circuit and some more advanced ones, which can make it so you can charge battery stacks at same time you run motor. "
http://uk.youtube.com/watch?v=nGGL7Hs0p5Y
this is the 2nd half of the rotovertor demo.
This particular 3450rpm marathon-brand 3ph 2hp AC motor shown in the video I eventually got to run on .18amps (180milliamps) at 120Vac with no load on shaft, using a 9uf run cap.
The rotovertor is a discovery of Hector Torres and has been replicated and tested by hundreds of people since it was introduced publically around 8 years ago by Hector.
This sort of motor has the ability to actually "run itself" if you spin a super effecient generator, and also pull out power not only from the generator, but also what the AC motor itself in rotovertor mode makes in additional power from its third "virtual" phase - this phase works more or less like a "rotary transformer"
Study the rotovertor circuit and you will see that the third phase does not draw electricity, but in fact makes AC power itself that can be extracted.
Look on my geocities site for the rotovertor circuit in "circuit diagrams" link - also look at the circuit there in that link that uses a 2nd trigger-transformer to pulse-out power from that 3rd virtual phase at the motor's sinewave peaks to charge 2nd battery stacks so there is "no reflection" to the input power to the motor itself. This can also be done using a strobe-light light sensor trigger circuit too.
my site: http://www.geocities.com/koneheadx/
Also look at link #16 which shows a 5hp 1850rpm rotovertor AC motor spinning a Bill Muller design type of dynamo/generator.
This generator should have its power-out pulsed out at the peaks of the sinewave that the coils prodduce to eliminate "lug" to the motor as it spins the generator.
Also look up lots of good rotovertor information at this site: http://www.panaceauniversity.org
also look through some of hsi circuit schematics either on the page he linked (geocities.com/koneheadx) or access them at
http://merlib.org/taxonomy/term/3806. enjoy.
ramset
Esa
As usual an amazing amount of wonderful info Thanks, much to look at and learn
Oh BTW WITTS up? http://www.overunity.com/index.php?topic=6192.0;topicseen
Thanks again
Chet
Thanks Grandma
