High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
rayco
Hi Jomumu
  I did this a few years ago. I believe the video you are referring to did not show the 2 foot diameter balloon attached to the top of the unit. The balloon stored a few liters of gas before the engine was run.
  How much fuel does a motor require to run on Hydroxy?, It takes as much as it needs. All motors and conditions are differant.
  I build thing to last.
The next thing is to increase the output of this unit. I will install another alternator on the motor, remove the voltage regulator from it, and pulse its input.
Even though the output will show a higher voltage, the actual voltage going to the cells will be lower.
The water capacitor  theory is a good approach.
  What frequency should you pulse it at?
I have not checked it yet, but I will put a Freqency generator and counter on the input to the cell pump in a few volts and see where the voltage peaks out.
What people are doing wrong on this forum is their approach to the problem. I see people doing things here that were done 25 years ago. Do more research and some of the basics will become apparent then build on them.
  Basics?  Would you store a bunch of natural gas in a plastic box and then run a tube to a possable source of ignition and say it was safe?  Of course not. So what do you do?
Make some thing that will not explode. I ran a 50 foot tube to the one I built and ran the unit for a wile. lit the end of the tube with a spark plug. No problem. Did the same thing with a plastic electrolyser and it blew up. Look at the junk they have in the ads on this forum. They are a law suite waiting to happen.
Bottom line is don't make thing to complicated, you don't need to.
Rayco
rayco
One more thing about the 5psi thing.
   That was to reduse the foaming and boiling in the cell, It also will give you a smother flow of gas.  I tried it using differant size hypodermic needles. you don't need it to just add gas to the motor. If it is foaming and boiling you are not making gas you are making tea.
Rayco
Jmiller1948
Newbie here,
         I have been researching for about a month now Mr. Stan Meyers invention. Though I have found no figures on the quantity of H2 created. I found an excel file that calculates normal electrolysis yields but for a 3.0 liter car motor to run purely off of H2 it requires a large electrolyzer which presents many concerns along with weight. I have read and watched articles and videos that say High voltage is key or high current, and even electronic resonance which Mr. Meyers seemed focused on. My question I pose is what were Mr. Meyers' yields per in.2 and consumption rates of H2O with and without electrolyte?
        Next do you have plans for the electrolyzers that you have build? if so could you post them in any format you see fit as a reply. Your help and knowledge would greatly be appreciated.
thanks
Jason
PulsedPower
@Jmiller48
rayco posted a drawing a few posts up illustratings a conventional multiplate electrolyser, it is self explanatory. IMHO the design is compact, efficient and easy to build. If you are after a conventional electrolyser you would be hard pressed to find a better design, coated titanium would allow one more cell on each side  at 12V but coated titanium anodes are not cheap.
give_it_away
I'm new to this WFC, I have been reading a lot about this WFC and what I have learned it that a lot of people are trying to replicate the cell but not the water injection. Is ther something I'm missing here. I'm also building one too. will post pictures when I get a few dings straighten out.
Why is everyone repilcating Stan's WFC when you can focus on Stan's water injectors. He steams the water and passes it throw micro tubes mixing it with air to reduce the high explosion rate (2.5 time more than fuel) to regular fuel level and then ignites it with 20,000 volts at 50khz. Isn't safer than traveling HHO through a gas pipe from the end of the car to the front (or under hood), also you have a box or cilinder of HHO ready to explode when near a heat,flame or/and spark source.
I also see that there is a lot of people not releaing some secretes like stan and taking to his grave and I wounder why his brother is not saying anything since he was the one who built the VIC and knows all our answers. Do you really think you can just go out and sell this technology to the world without the Oil, other companies and government interfering. There is no such thing as free to them. I think you will end up like Stan.
I think we need to make it and let it out to the world. Because That's what I'm going to do. Because there is a lot of people that don't have the $$$ to buy such technology but can have the $$$ to build one. and Why make the millions if you and your family can't spend it when the world dies from all the pollution and exchausted resources.
