Thanks to ALL for your help!!
water vortex generator
Started by innovation_station, March 27, 2007, 11:35:55 AM
innovation_station
an idea i came up with last night
it is a water vortex generator where you have a big tube and it is filled with water in the center you have magnets in cased in a floting chamber in the shape of a cone and you suck water from the bottom and return back in the top causing the water to whirl pool around making the magnets spinn and around the outside of the tube you have collection coils to collect the current a drawing comming soon
as i said i have many ideas but no money to build them so i will give my ideas away for every one to build
it will take little engery to keep spinning
back to the drawing board yo
is
Flit
The power required to pump the water back to the top will be greater than the energy that could be obtained from the waters motion.
innovation_station
agin like my turbine it only takes a little water to keep it spinning a lot at the start but a little after the fact
now if i used many strong magnets and  it flots in the water and if i have no steel in my colector coils then will it still require more energy to operate than produce
i dont think so
the steel causes drag from the mags so get rid of the steel it will not be needed any way
for the colector use many and i do mean many peices of fine copper wire in a cone shape like coil
and if put as close as posible to the rotating mags in the water in the tube
i will make a drawing soon as i have time
is
Flit
If you use many strong magnets what is to stop them from all sticking together and sinking to the bottom?
innovation_station
ok here it goes
and as i said i have not built this yet but i will
the mags will layed out in a corkscrew fashon and they will be drilled in my cone mags should be around 1" in length and .5 " sticking out the mags work as the fins on a turbine the water grabs onto the mags causing the cone to spin the cone must be air filled so it flots in the water how to achive this is still in thought
this is simple as all of my inventions
or the cone could be made of styorfoam the mags epoxy to the foam the cone should be the same shape as the vortex and sits in side the vortex
we do not need a large volume of water to make this work
in fact the less the better and the faster we pump the water the better the output
also the more  and the smaller the mage the better the result
if for some reason this does not make sence
you are thinking way to hard
simple as it should be
is
