The storage thread
Started by joe dirt, May 02, 2007, 09:02:19 PM
joe dirt
Edit: this thread will be used primarily as a dropbox of ideas and 3d models of those ideas  :)
        will be cleaning it up to make it easier to follow and as more info comes about.
   I,m not sure if this has been done yet, so I,m putting it up on the board.
   The prime mover (in the middle) is the P.F.T. from jln labs,  here,s the link
http://jnaudin.free.fr/html/pftm2.htm
Attached to the ends are Faraday disks (homopolar generators) I thought the concept
   is worth investigating 8)
http://en.wikipedia.org/wiki/Homopolar_generator
Dirt
P.S. you need the program "openfx" to view the 3d model,  the zip was archived with
      7zip.
joe dirt
Hello all
The reason why I thought this could work, is that a Faraday disk has little or no
   back torque from what I understand,  could be wrong though,  and the P.F.T. has
   little current draw (according to the tests at J.L.N.)
Dirt
Low-Q
Quote from: joe dirt on May 09, 2007, 01:10:28 AM
Hello all
Dirt
The back torque on a Faraday disc is in fact quite high. Just try to move a strong magnet close to a aluminum plate, and you'll feel the back torque. Try to make a magnet glide down a 45 degree or 90 degree aluminum plate. The magnet will sag quite slowly until it leaves the plate.
Br.
Vidar
joe dirt
Br.
Vidar
Hello Low-Q
Thanks for the info, but are you certain the faraday disk operates using the same
principle mechanics?    This taken from the Wiki:
QuoteLike all dynamos, the Faraday disc converts kinetic energy to electrical energy. However, unlike all other dynamos, this machine cannot be analysed using Faraday's own law of electromagnetic induction. This law (in its modern form) states that an electric current is induced in a closed electrical circuit when the magnetic flux enclosed by the circuit changes (in either magnitude or direction). However, the circuit in the Faraday disc is parallel to the magnetic flux vector and therefore encloses no magnetic flux. Therefore, Faraday's law does not apply to this machine.
Appreciated
Dirt
Gearhead
Faraday disk generators are well known.  They power rail guns, atom smashers, and various welders etc.  If they had no back torque someone would have noticed.  There was a lot of discussion and misinformation about homo polar generators in the past.  Some of the atom smasher type generators put out in the neighborhood of  700,000 amps at 8-12 volts.
