Thanks to ALL for your help!!
Triple Pulse Generator using cheapish parts
Started by Peterae, May 13, 2007, 07:22:08 AM
Bruce_TPU
Hi Mike,
I understand some are skeptical and some are frustrated.  I believe the engineering reports on the TPU.  Much more convincing then the videos and very legitamate by very credentialed professional people.
SM said that if just one little thing is out of place the TPU will not work.  We have clues, good ones I think.  I think enough to get a real good start.  I lack equipment and need a tube circuit built to really get started.  I think in reading SM's posts, He suggests going the tube route because it is "easier" to see some "power generation".  He mentions their speed, and many other things.  But if everone will read the full post linked on my last post he tells of the frustration trying to get the same results using SS.  And THEY KNEW HOW the generator works.  So we as one large build team, are trying to find the right avenues and continue to gather knowledge and garner clues.  You are a good man and have offered many on this forum help.  If it turns out that someone out there or my guys helping me, get a tube circuit working in a tpu, we will need you and others to design it to SS.  But WE WILL KNOW IT WORKS! And that would be an exciting achievement for everyone on this forum and could change the world.  I hope this encourages some out there who have grown discouraged or frustrated.
And those wanting to go the SS route, at least follow SM's advice about soldering 1/2 inch above the board and keeping the SS in the center of the TPU.  Thank you.
archon79
The people who know most about tubes are audio amp designers. It's basically the last field that still specializes in tube curcuits. We need some of those people here I think
MeggerMan
Hi Peterae, MrAmos,
The AD9833 looks like the business. sine/triangle/square waves.
What more could you want.
I found a link here showing some PIC code:
http://www.picbasic.org/forum/showthread.php?t=3407
Perhaps we can all put our heads together to come up with a PIC or AVR based 3 or 4 channel DDS function generator with LCD display.
Farnell sell the AD9833 for about 4 GBP if you buy 10 or more.
Anyone in the UK want to goes halves?
http://uk.farnell.com/jsp/Semiconductors/Signal+Conversion/ANALOG+DEVICES/AD9833BRMZ/displayProduct.jsp?sku=1143310
We could use the same clock for the CPU as the DDS.
Rob
Thedane
Where does it say that you NEED 3 function generators?
If you have 2 generators, each with a different frequency, you'll generate a 3'rd beat frequency.
This is called binaural, and is often used in music to generate special effects:
http://www.binaural.com/binfaq.html
shuzammy
The topic of binaural beats is an interesting and noteworthy one.  However, these are frequencies that are "deduced" by the mind (at least in theory) as it subconsciously "makes up the difference" of two independent frequencies.
For example, the difference between a left channel frequency of 50Hz and a right channel frequency of 57Hz is 7Hz.  In this case, 7Hz is said to be the binaural beat frequency.  This particular frequency happens to fall within the Theta brain wave range of 4Hz and 8Hz.  Hence, by listening to two channels of audio with a difference of 7Hz (or anywhere between 4Hz and 8Hz for that matter), one may, in theory, entrain or induce the mind into Theta brain wave activity.
In the case of a TPU, however, we find that when SM powers up and down the larger unit, he flips the switch three times, once for each frequency.  This leads one to believe the third frequency is not virtual (as in the case of a binaural).  One may conclude that the third frequency is not likely a "difference of" but rather the summation or a harmonic of the Primary/Seconday.  Hence, it may be fairly stated that the third frequency is "induced" rather than "deduced".
Binaural beats is a very insightful connection and I'm glad someone brought it up.  After all, everything is connected.
