Proof of concept - perturbing a static magnetic field
Started by bob.rennips, May 30, 2007, 12:57:25 PM
0 Members and 53 Guests are viewing this topic.
Bruce_TPU
@ Bob.R
In brnbrades case yes.  In another persons case, who had PM'd me, no.  Just the tiny speaker on an input to their coil.  It was not electrically connected.  Sounds wild I know.  But I have seen some small strange things today.
@ brnbrade
I am sure I must have wound your coil wrong.  I first wound 1000 turns of 30 gauge wire around a straight piece of 1/4" pvc for the length of 3.5"  Over the top of this I wound 24 turns of the primary, using 22 gauge wire.  This is why we need exact details, porfavor.  :)  A drawing would also assist.  Including how you connected to your walkman.  Thank you.
Volts:
Headphone jack stereo wire - unplugged
.005 v
Plugged in - No gain/volume  107.7 FM
.103 - .110 v
Plugged in - full gain/volume 107.7 FM
fluctuates LOW - .165 v        High - .629  <-- VERY interesting, with increased gain is increased voltage, everytime!
Then wired it to primary side of coil:
Secondary No volume
.000 - .002 v
Secondary Full volume
.009 v
Large magnet near it did not change anything.  A large magnet over the entire coil did not change anything.  I unwrapped the electrical tape, thinking it was hindering the vibrations of the primary, but nothing.  Each primary lead was connected to a stereo output lead.  Each secondary lead was connected to the voltmeter.
Either my coil was wrong, wire size?  length?  etc.  Or how it was connected to the radio was wrong.  Or both.
Thank you for your time,
Bruce
bob.rennips
@Bruce
Try Orchestral music. It has a wide sound stage with specific position for various instruments on the sound stage. If you apply the stereo connection to a bifilar coil, it might be more interesting for you.
starcruiser
I wonder if he connected it to the headphone jack or the speaker output terminals on his receiver? Just a thought/question...
Regards,
Carl
brnbrade
After the test in high school support I post pictures and results.
My work and my time is this short.
Diverting the tests, my friend DJ said that certain sounds types use beats per minutes "bpm".
The more fast the beats, can improve the results. I will try weekend.
I will work in other device that will be definitive for me. I hope he/she works as well as the theory on him.
Will be ready inside of an or two months.  I wait.
karl
Hi, good results,
interesting formula from Hugh H. Skilling, "Electric Network", John Willey & Sons, 1974, regarding a situation of an RLC Resonator (or Network) which once loaded whith internal energy provides enough energy to swing perpetual (continous changing form of energy).
R^2 < 4 * (L/C)
Includung an PM causes an "Assymetric" and therefore "Nonlinear" introduction in the L-factor (loading in parralel mode, pumping in antiparallel mode).
We should engineer an "Factor of Motivation" which describes the property of selfexcitement (neg. damping).
How should we get into this stable sector?
Possible due to:
#Offset statically
#dyn. Offset due to interacting Waveforms
#canceling out R by using the skin effect (HV)
Best wishes
Karl
