Thanks to ALL for your help!!
all you need is spead diode to make tpu bealivet
Started by MACEDONIA CD, June 02, 2007, 03:57:49 PM
Bruce_TPU
@ Digilab
Thank you very much, both for your kind words and translation.  Perhap you would be kind enough to PM our other Macedonian friend, and see if he could give us a few more clues.  Is he speaking in reference to Otto and Roberto's setup?  Or something different.   What ever you can get from him would be useful.  :)
@ Macedonian friend
Thank you
@ everyone else
I wonder if I am the only one who thinks that what the macedonian tells us is eerily familiar to what SM said.
SM's words:
"If you had a short wire and you moved a magnet across it you
would always have limited potential because the length of wire
was so short.
OK now what if we increase the length of the wire to many miles
in length even with a very weak magnetic field moving across the
wire you still have a much greater potential flow of power
available.
If we put it into a perspective of power per inch it may be easier to
understand.
If you have a small magnetic field moving across a wire twelve
inches long it can generate an electron flow equal to lets say one
millivolt per inch.
If you move the magnet twelve inches at the same speed you get
12 millivolts as you transgress the twelve inches of wire.
Understand that I am trying to convey a principal that you can
understand for use in the future.
So, you have a wire twelve inches long and you can make 12
millivolts moving a magnet across it."
Either this Macedonian is a SM clone, or has read a translated .pdf of SM's posts,
or he may be onto something.  GK, Jason, Otto or Roberto might understand or figure it out after reading the translation.  Perhaps there is more RE coming off of Otto and Roberto's set up then they realize and it is not being picked up???  Unsure.  :-\
Cheers,
Bruce
wattsup
@DigiLab
Thanks for liking the joke.
Thanks even more for the translation. Please , please, stick around here for a while so we can speak with @Macedonia CD. We are only glad to learn more, but in one way or another, he has to realize that there are still many ways to interpret his total information to start building something.
You know, when I go fishing, I usually like to choose the lake. But right now with the limited information it would be like having to catch a trout in the Atlantic. No fun at all.
Things we need to know;
1) Coil diameter 6" but what is the height?
2) Coil structure material on which wire is wound?
3) Are both coils (secondary 40 turns, primary 20 turns) wound in the same direction and/or is one horizontal and the other vertical?
4) Can he give us the wire sizes.
5) Is he using only two terminals (2 and 3) of the BUZZ11A transistor, and is he using four of these transistors to make a bridge rectifier AC/DC converter?
6) The 250khz, is this a pulse on/off or a frequency?
7) 8 watts input, is this the total watts consumed by the pulser and the primary coil together? If yes, what is the input voltage to the primary?
When a replication is in order, it has to be based on common information so others can confirm the same device, otherwise we will have 20 different systems with some maybe working and others not. This will only create more confusion. The better the infromation to start, the less we will hound @Macedonia CD afterwards.
Thanks again for your kind assistance.
Motorcoach1
Macidonia CD is this the wire your speaking about ? and coil?
Bruce_TPU
Hmm...just doing some thinking tonight.
I have wound Otto's collectors and bought all the control wire I need.  Will finish this tomorrow and post pics on Otto's thread.
Let me tell you what I have been thinking about.  Let us assume for a moment that SM's TPU's collectors were indeed one turn each.   This leaves a huge gap in weight vs. actual wire, as I demonstrated on my thread, doing the reverse engineering based on the weight given of SM's TPU in the engineer's report.
So, what if What both SM and our Macedonian friend are trying to show us, that we need more wire.  But this wire would have been wrapped in the same direction as the collectors, under or over them.  And then perhaps through induction, more amperage is then created.
We know from Otto, that our TPU has a rotating magnetic field.  This is the "weak" magnetic field referred by SM and the Macedonian.  The Macedonian suggests in his PM to me to wrap 20 turns over the collector.  As Grumpy said, this would indeed suggest induction, but again.....THINK NEW TECH... Perhaps the induction could be a result of the high frequencies.
You see, some time ago on my thread I mentioned that High frequencies can go right through solid objects.  I do not think anyone has picked up on that.  Perhaps there is much more energy being produced currently in Otto's and Roberto's setup then anyone realizes.
Like I said....Just thinking aloud..  ;)
Thank you for your time,
Bruce
Bruce_TPU
Our Macedonian friend suggests using speed diodes in his setup and that it is his key to success.  Not being an electronics guy, I wanted to know what that was exactly.  It is both facinating and fits in with some things that has been discussed for months, as you will see in very real ways.
Definition:  (I exerted this pertinent part.)
It is often said that the Schottky diode is a "majority carrier" semiconductor device. This means that if the semiconductor body is doped N-type, only the N-type carriers (mobile electrons) play a significant role in normal operation of the device. The majority carriers are quickly injected into the conduction band of the metal contact on the other side of the diode to become free moving electrons. Therefore no slow, random recombination of N- and P- type carriers is involved, so that this diode can cease conduction faster than an ordinary PN rectifier diode. This property in turn allows a smaller device area, which also makes for a faster transition. This is another reason why Schottky diodes are useful in switch-mode power converters; the high speed of the diode means that the circuit can operate at frequencies in the range 200 kHz to 2 MHz, allowing the use of small inductors and capacitors with greater efficiency (*Our Macedonian friend is using 250 KHz frequency) than would be possible with other diode types. Small-area Schottky diodes are the heart of RF detectors and mixers, which often operate up to 5 GHz.
Now, what can we do with this information...
Cheers,
Bruce
