Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
hoppfield
Quote from: seychelles on November 03, 2015, 10:36:55 PM
so if one goes into outer space out of earth bound gravity and one spin a flywheel
will it eventually stop.
  It will. There is what scientists call the 5th Element which might be nothing more than those zippy little neutrinos.
They have what is called the Cosmological model which is wrong. The basic reason why is that stars (suns) are moving faster through the universe than physics allows for. Basically, they should have suffered catastrophic failure but haven't.
  With a flywheel, it transfers energy. An early example of this is the term "balls out". This refers to generator at max rpm's using 2 weighted balls to control their RPM. This was in the days of dc power.
The basic difference between ac and dc power is distance. C power suffers a high entropy rate and is still used in poor economies.
With ac power, it is more expensive but suffers a lower rate of entropy over greater distances. There are other factors that decide whether an economy should use ac or dc power but that is a different subject.
memoryman
@seychelles: "well just recently in the news an engineer invented this new motor that uses 30 % less power than any other motor on the planet..so which motor is 90% efficient.the one that this guy just invented or the one that you allege is 90 % efficient." if you are referring to the Keppe motor, then you are mistaken. If not, please give the name of the inventor.
a flywheel is passive, i.e. it STORES energy that was put into it; that energy can be extracted, but no more.
ARMCORTEX
If you go through my prrio posts, I have linked many videos, let me gather them again.
Many videos, from many people. Some are HUGE and very expensive.. 100,000$ +.
Money talks to me more than forum people with no money.
Some people, seem to think this is worth spending money on.
I say its worth investigating. Nice work Jeg.
There is not much theory out there, regarding this flywheel effect, here is one of the major ones.
Is there more out there?
http://www.resonantfractals.org/Magnetism/Flywheel.htm
hoppfield
 this is the gravity part of the forum. If you guys missed this, who knows what else you have missed. I doubt it matters much, you know details.
ARMCORTEX
eka elektirik
AG energy
Technokontrol
These 3 startups, has huge builds.
Smaller builds, too many to mention.
https://www.youtube.com/watch?v=CoyDX0A02gw
This one from bangladesh, is interresting.
Perhaps the goal is to create some kind of resonance of impulses within the belt. BY making the power input disconnect and reconnect somehow, or have a double pulley with really shitty connection and bumps.. The motor can be seen as a drag if we depower it, the conection can also be bumpy or eccentric. Not the flywheel, I dont suggest eccentric theory of flywheel, but you may try, From what I see of claimed working device I see no eccentricity of flywheel itself.
Exept for Pejic on his prototype bycicle,, but that seems to dissapear in his metal box.
As Krstan was telling.
Ag energies, use hydraulic input power, box that seems to be loose big flywheel, BIG shaking, box is getting pummeled.
A hydraulic Osillator of some sort,  there is the deliberate looseness of the chain, the box had very shaky structure. Technokontrol, almost identical.
