Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
zero
Yes, a patent will never work.  Nor will industry.  They have both been corrupted
long ago.
Heres a thought...   If you put the info out there, and put up a link
to Donate money to the Invention,  Im sure the people would
drop tons of cash in as a Thank You.
Make no mistake, people will not donate untill they build
the device and knows it works.  But after that, I think you
will get a nice kickback... as well as feel much better
that our world is in better shape because of it.
(and healthier, cause the air is cleaner)
vondesastre
hey guys  sorry to barge in
after numerous calculations and synthesys>>> i think i found us a way to get real free energy
>> stay tuned
i will be needing as much feedback as possible from you
lets do it together
i guess that this is the purpose of this forum anyway
i stand on grounds that >>  many of our predecessors have opened ways but they all got stuck in their single lined research thus were unable to see the bigger picture
please feel free to join in
http://www.overunity.com/index.php/topic,3029.new.html#new
any contextual input will be welcomed
thanks in advance
ashtweth_nihilisti
Getting more details now as far as i know he will still let us measure his set up more details as i find them out
latest email to me
First build a flywheel that will produce at least twice as much energy as you need to drive your alternator when finished you should have trouble seeing it moving as it runs in its own space, After a few trial runs i built one by having a h-t steel shaft keeyed each end before a flange or a disc was slipped along to the center and welded the flange was then drilled and tapped to take studs, using a router i cut a circle 600mm in diameter out of custom board with a hole in the center to take the shaft this was attached to the flange using studs with washers and lock nuts the second circle had a hole in the center large enough to fit over the flange this was fitted from the other end and screwed to the first wheel by doing this i could try diffrent speeds and drives until i was satisfied i had a combination that would work with what i had which was a .075 hp single phase electric motor and a 3.5 kva alternator,The flywheel ended up being 72mm thick and 590mm in diametor i then fitted a steel band around my wheel this added more power my theory being if you create centrifugal force you can drive anything as long as the wheel keeps spinning I ended up with an alternator fitted with a 4.5inch pulley driven by a 9inch pulley the alternator speed was 3146rpm at that speed it was easy to run electrical applicances for a period now to the most important part to keep the wheel spinning i wanted to build a power grid which had a single power supply to a switch that worked on a roating system to this i would have 6 identical electric motors connected they would all drive to a comon shaft in the center imagn a clock with your motors situated at 1-3-5-7-9-11 , The switch would direct power to one motor at a time with a overlap that provided power to the second before the first was switched off this means one motor is working while the others are cooling down on this drive shaft i would have a smaller flywheel to compensate the power required to drive 6 sets of belts as the motors are like the alternator they require very little power to spin Drive this shaft at approx half the speed of your motors from this shaft double your speed to your main flywheel then using pulleys as large as possible drive your alternator All you need then is a simple device that prevents your alternator producing more power then your system is capable of maintaining. I tried very hard to create enough interest in my invention to be able to fund the end product but i feel i am wasting my time so hopefully one of you good people will have more luck then me ,as for testing one of my original machines it would be a waste of time as no mater who tested it it would not satisify everybody thanks for your interest and good luck,Chas    PS I would like this passed on to as many as possible.
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
FreeEnergy
Quote from: ashtweth_nihilisti on August 21, 2007, 12:50:08 AM
latest email to me
sounds good, any drawings/blueprint of how all this works?
ashtweth_nihilisti
 ;D ;)
