Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
ashtweth_nihilisti
Quote from: hartiberlin on September 09, 2007, 10:38:51 AM
Hi Ash,
if you will be at the 15th again at Chas?s house,
then please try to ask him to put all the ball in each holes
and see, if it starts itsself rotating.
Probably it will not do it.
Maybe he has found an effect where:
E kin= 0.5 x m x v^2 is not equal to E pot= m x g x h
So if a mass converts its stored energy due to its height h
and falls and  hits a target,
then maybe it has more energy than E pot = m x g x h
predicts ?
This is probably what user zero has pointed out.
Guys i am finding it hard to keep up with all the posts and Bantar, can some one fill all there request and test info in ONE thread? i have also lost Stefans request for the OHM resistors post can some one find it please?
Lawrence, thank you for the document! will review it now and add it to the script, all tests will be all filmed this weekend.
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
sm0ky2
Quote from: ashtweth_nihilisti on August 27, 2007, 10:36:02 PM
Stefan Exactly, what happens when you put a child on a 'swing' and she swings very high and you only tap her with little energy to keep the momentum going.
But how do you extract the energy from the swing so the 'inertia' stays the same?
Perhaps Chas has to a degree done this.
In the RV resonance 'swing' the peak sine waves  'tap' is the extracted OU, well thats how Daivd Kou keeps his battery charged he cant explain it by any other conventional means,its  a little more elaborate with half waves and ful waves AC theory etc, but thats the 'gist' of it. Im not sure if Chas has done the inertia process, your 15 mins test will clear that up.
Ash, it is interesting that you make that point, that very principle is used by at least 3 other inventors to achieve what they (except 1) claim is "OU".
1 man, actually utlizes this force, in what i view to be an OU system, but makes no such claims.
using a pendulum with a double-fulcrum to operate a lever and extract force, wiht no losses to the momentum of the pendulum. I'll try to get his name right : Veljko MilkoviÃ,,‡  i believe
hansvonlieven
Good Lord Lawrence,
I just read that thing of yours. You sure go to a lot of trouble to talk a lot of rubbish.
Hans von Lieven
hansvonlieven
Correction Smokey, Milkovic does not only claim OU, he claims Perpetual Motion.
Hans von Lieven
ashtweth_nihilisti
sm0ky2, easy to replicate Claims for the OU reported RV system are posted in the Roto verter thread
Also check gravity powered concpets from panacea's university where Milkcovic's plans are.
We have begun BOTH those replications and will post our results in the appropriate threads.
