Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
bob.rennips
It seems the lower the hertz the higher the voltage. I tried 2Hz and got 100+kv.
I'm thinking this is simulator stuff up now...
kokomoj0
Bruce_TPU
Well, that is okay, Bob! :)  LOL
It was fun to play with....who wants to try their replication at 7.23 Hz as one of their frequencies??  It made me a little shy! LOL
kokomoj0
the only  thing i know how to do is RANT
bob.rennips
Quote from: kokomoj0 on June 21, 2007, 02:07:39 AM
Quote from: btentzer on June 21, 2007, 01:53:59 AM
@ Bob R.
HELP...please verify!!!
I did an edit of somethings:
3.5 volts input
Square Wave
7.23 Hz         <------ I have said this frequency is in the TPU because of the clues!!
OUTPUT
30.36 KV
What do I say, I am speechless!
so you put 3.5 volts in at 7 htz and got 30,000 volts out?
What was the input current and the output current?
kokomojo, put brain in gear before operating mouth!
It's clear from the last few thread posts that we're talking about the simulator.
Get off the case with the input/output stuff. It's getting boring.
At this point we're examining anomalies.
We believe that identifying and then fully utilising these anomalies will result FURTHER DOWN THE ROAD, in an overunity device.
I can categorically say that now the device is NOT OVERUNITY in its present form.
