Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
Bruce_TPU
Quote from: sugra on June 25, 2007, 12:04:58 PM
@Btenzer:
   That is correct, that was two seperate gens running using only the positive lead from each. No grounds were hooked up. I have been trying to figure out how to achive some sort of terminating point for each signal with out using the grounds. Not sure how I would do it.
   If and when I get my fet drives in the mail, I will be trying that again with really short pulse durations. Then I will see if that output has any power asociated to it. Laterz
@ Sugra
I would bet the farm that it will!
@ Everyone working on the ECD
If you want to see power, TAP into the bottom big coil of the ECD from a control coil, with Roberto's Mosfet, driver setup, and signal generator.  Next TAP into the smaller loop, from a control coil with IDENTICAL signal, but different source, ie..signal gen, Mosfet, Driver.  Tap into the smaller loop so that those signals will be sent in direct opposition of the others.  BE SAFE!  ;)
The next experiment would be identical with two frequencies, and then three!!
Happy Days!
Bruce
ronotte
@Darren,
hi, here are the measures done on my 6" ECD equipped with CC as per my TPU=ECD doc:
- Primary - R=0.5Ohm, L= 15nH
- Secondary - R=3Ohm, L=0.23mH
-Primary/Secondary intercapacitance = 485pf
-Mobius interwire capacitance = 74pf
It would be interesting to insert them on your model and compare the results!
Roberto
MeggerMan
Hi,
The DDS 20 kits (x 2) arrived today.
Easier to build than I first thought, they have already added all the surface mouted components, not much of a challenge is it.
http://i100.photobucket.com/albums/m25/kingrs/dds20_kit.jpg
Rob
chrisC
@meggerman
Thank you for posting the DDS-20 kit. I sure would love to see your kit running. Please let us know if the output driver will drive the Control Coils directly or do you still need special fast switching output drivers?
Also, are you in Europe or the UK where you can buy these parts. Apparently there is no distributor in the US.
chrisC
z_p_e
Quote from: ronotte on June 25, 2007, 02:02:46 PM
@Darren,
Roberto
WOW, Roberto!
Something doesn't look right.
Your document shows:
- 10.5 meters of 0.35mm wire for SECONDARY
- 4.2 meters of 0.5mm wire for PRIMARY
The closest I was able to match with AWG is:
#24 = 0.5106mm compared to 0.5mm and
#27 = 0.3606mm compared to 0.35mm
(So worst case match here is 3% error.)
Because the secondary length of wire is only about 2x the length of the primary, the secondary inductance should only be about 4x the inductance of the primary.
With the numbers you gave above for inductance, the secondary inductance is over 15,000 x higher than the primary !!  :o Perhaps the 15nH is supposed to be 15uH ??
Could you please double check your measurements ?
Thank you.
Regards,
Darren
