Thanks to ALL for your help!!
Bird on a wire
Started by WaveWatcher, June 21, 2007, 02:46:37 PM
Bruce_TPU
Quote from: BEP on June 27, 2007, 09:36:15 PM
From what I have seen here and the results you all have posted it appears that the two signals should be 'electrically' of different origin and destination. That could mean a common ground but certainly would mean they are isolated (capacitive or inductive coupling) from each other. I do believe the difference between them could be as little as a phase variance but whatever, they must induce different rotation rates for each of the magnetic fields being produced. The difference between the two speeds will be the mixed pulse rate of the D.C. output.
Making electricity is trivial to what must happen to make this work. We are talking about momentarily creating unipolar magnetic fields in ambient atmosphere. Yet another thing that can't be done.
And having a vortex on one end does mean there must be another on the other side. This is in the books it just doesn't usually sink in.
'Theoretically speaking', when you look down into one you will see a red-shift. When you look up into one you will see a blue-shift. If you have a good old fashioned mechanical watch in the middle it will appear to loose time from above and gain from below.
If you have a compass in the middle it will stop at any place friction wants it to stop.
As is in Fresnel optic rotation equipment g<1 - in the extreme case.
But we don't want to go to the extreme case, do we? Just make some juice.
When you think you have a lazy rotational difference between the two fields - stick a compass in the middle. See if you can make it point where you want it or spin the way you want just by changing the phase/speed difference between the two fields.
If you can you should probably start taking numbers.
If it is rolling like a wheel then I don't know. It depends on where how and what your signals are.
Hi BEP,
And no, not the extreme.... LOL   ;D  Just make a little juice.  Blue light only!
Have you had the opportunity to read through all of SM's clues contained in the .pdf ?
I think there is a low frequency somewhere involved with these other high frequencies.
BEP, one investor wrote to the other that the 6" was apparently "tuned" to 7.23 Hz.
How would one tune the coils to that low of frequency?  And we know for a fact there are High frequencies in the collectors at the same time.  It is a conundrum.
Also, I have been thinking about the cutaway picture of the 15" after it was sliced with a saw to prove that there were no batteries in it.  Result:
Top of Toroid - Two lamp chord type wires, one on top of the other.
Bottom of Toroid - The same.
It makes me think of transmitter on top, receiver on bottom and resonant cavity between.  Perhaps one resonates at VLF and the other UHF and then somehow between the two?   ???  (only if there is no electromagnet as I think, at 7.23 Hz. :) )
Cheers,
Bruce
EMdevices
You might enjoy this video, it's so applicable to this discussion.
BEP
No. I haven't seen that and many other things mentioned here. I have and continue to re-read the Sm clues. No bandwidth here and constant disconnects.
My theories are crystalizing. There are different stages of the process. Each solidly founded in classic physics. Much too much to go into with my current deadline.
Regeneration is happening more than once. Three sisters is a major part of the process. Conversion of the Elect part of the signal to magnetic and back again. Perpendicular does not seem to mean in the mechanical sense but in signal relationship.
Testing each step one at a time and attempting to optimize each. In the process I stumbled across a bi-stable PM. You bump it with a magnet of opposite polarity and it changes its own polarity. Not focused enough to make OU motors work but it sure confuses a compass! and not working on same part of spectrum as SM devices.
Regen appears to be key to first step. Main coil (antenna) High-Q at Shumann base and 2nd and third bases (not harmonics). This is DC part.
Second coil is feedback/regen coil as in Tesla regen circuit. This coil is high current/low voltage (reason for heating problems) - slightly lagging equivilant of main coil but lower Q and broader bandwidth and needs AC (two small sisters) to slap the Elect part of base (DC) into magnetic part of base as a kick. I know - injected sig is said to be square DC pulse - perhaps from our perspective but it needs to look like AC to the other sig.
The seed appears to be a base Schumann (DC)...must run now.
hartiberlin
Quote from: EMdevices on June 29, 2007, 01:33:08 PM
Well, in German language one would say:
Echte M?nner ohne Nerven...
Wow...
Not a job for me...
;) ;D
BEP
L?d, L?d, L?d!
