The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
Bruce_TPU
Builders Replication Details of the silent brnbrade coil
Wattsup
Build replication details:
http://www.overunity.com/index.php/topic,2630.msg38187.html#msg38187
A New Way To Wire The Coils:
http://www.overunity.com/index.php/topic,2630.msg38714.html#msg38714
REPLICATION DETAILS of the brnbrade coil
Four variations have been shown thus far.
1) Coils + 3v Battery, DC-DC 58 vdc out.
2) Coils + 3v Battery + Sound (two channel positive only) DC-AC 250V out.
3) Coils + Cap (330 uf 200v) + Cap (62 pf or uf(hard to see) 400v about 4-7v ac out
4) Coils + 4 Caps (hard to see values) about 20v ac out
what kind of iron rods did you use ?
Iron
2. Did you use alufoil or aluminium tubes around the coils ?
Alufoil
3.  I use aluminium varnishing
STEPS TO FOLLOW TO BUILD COIL LISTED BELOW!!
Yes,  Core -> insulating -> aluminium -> insulating -> fine wire coil -> insulating -> aluminium -> insulating -> Thick wire -> insulating -> enjoy!
How many turns of wire did you use ?
MacFarland mentions more wire more better the result.
In one posting was said 35 turns ?
In my device is 35 turns.
It can be more turns or less. I didn't play with this still.
Is this the big red wire ?
Thick red wire 35 turns.
How many turns does the fine wire have ?
???  I do not know
Parts needed:
1.  Aluminum foil
2.  Iron or steel core (large spike, landscape nail, etc.  Be creative. :) )
3.  1/2" Aluminum Tubing
4.  Fine Wire -  Thin wire looks like 0.4 to 0.5mm diameter.
5.  Thick wire - Seems to be about #12 awg Solid.  Thicker is better.  Thick wire looks like single core from 13 Amp twin and earth ring main cable
6.  Aluminum varnish
How to Build
Step one - Take your iron core and insulate (with dielectric material-see picture it is painted on and is black.  you can see some scraped off of end.  What can we use?)
Step Two - Insert iron insulated core into aluminum tube
Step Three - Insulate aluminum tube (aluminium varnishing)
Step Four - Wrap fine wire (need awg. someone look at the picture,please!) around aluminum tube
Step Four - Insulate fine wire (aluminium varnishing)
Step Five - Wrap with aluminum foil
Step Six - Insulate foil (aluminium varnishing)
Step Seven - Wrap Thick wire
Step Eight - Insulate
Step Nine - Enjoy your OverUnity brnbrade Coil!
MAKE TWO IDENTICAL COILS
How to wire brnbrade Coils
Easy to follow Steps:
A.  Place both coils flat on table.  Place one coil above the other coil.
B.  Take the thin wire on the bottom left coil and connect to the thick wire of the top coil on the same side.
C.  Take the thin wire on the top left coil and connect to the thick wire on the bottom.
D.  Repeat steps B and C for the right side.  (This is called a Mobius)
Input whatever power you want to test.
REMEMBER the oscillations!  Stereo signal, opposing (sound familiar :o)
Pulse with your mosfet driver setup, signal generators, Walkman, whatever you want to test it with.
There, I have spelled it out.  If you want to draw a circuit I will add it here.  As well as information I have requested.
REMEMBER to test in a STRONG magnetic field.  Good results I think.
Post all results in this thread for others to learn from.  Thank you.
____________________________________________________________________________
brnbrade
bob.rennips
So to check my understanding. He has 3 volts going in and 52 volts coming out. He hasn't been able to measure any current, AMPS.
Has he done anything that could act as a proxy to amp measurement ? e.g. The brightness of a light bulb ?
With the information available at the present this sounds like a step up transformer, in which case the small amps from the battery will be even smaller at the output ?
I'll keep an open mind until more information is available.
EDIT: Now that more information is available - the information in the first post was NOT there originally !! - and the subsequent linking to the Farland patent which also wasn't mentioned. I believe this device to show unusual, unexplained results.
brnbrade
Bruce_TPU
And with the sound pulses you read 250 volts!
What could cause that??
Did the voltage change with the beat of the music, or was it the same?
Was the volume up or down when you tested?
