The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
Bruce_TPU
Quote from: chrisC on July 02, 2007, 04:13:31 PM
Much as I apprecite Bruce's help, inaccurate translations is as bad as injecting extra stuff or conjecturing on the behalf of the 'inventor'.
@ Chris,
I never Translated.  He wrote to me only in English, and I posted every one of his messages to me on this thread for all to read and interpret as they see fit.
Also, a Portugese translation of a list of questions has been sent to brnbrade from Doug.
Thank you,
Bruce
jacob
Quote from: EMdevices on July 02, 2007, 01:00:40 PM
Question:  How did you measure the amps?
Answer:  No mesure. I no amper reader.
This is strange, his meter can do Amp readings as well, does he not know how to use it?   As in "I no good at reading meter?"
Hmmm
EM
Quote from: chrisC on July 02, 2007, 01:05:24 PM
EM:
That statement was made a couple of weeks ago when he first posted his discovery and he did not have access to a ammeter.
chrisC
@ ChrisC
The video he posted some time ago shows the same meter we can now see in these pictures.
@ EM
The meter he has can measure DC ma, but not AC. That is why he cannot measure the output power. In a earlier post however, he mentions an output of 52 V and 1 A. So it's kind of contradictory...
@ Bruce
The more I look at the picture you posted (and sent me - Thanks) it seems to me that the orange wires are soldered to the buld terminals.
@ Rich
You can find the answers to many of your questions in the picture or in previous posts. Here is what I have gathered so far:
When he is feeding power to the coils, is he using only the battery supply shown, or is he using output from the radio at the same time?
Its either the battery supply or the output from the radio without the batteries.
When he's using output from the radio to power his coils is he using white noise?
No, he tunes to a specific station.
The radio he uses, what kind is it? Is it battery powered, or plugged into a wall?
He's using a Walkman type device, so presumably powered by 2 A cells.
Jacob
Doug56
I sent an email to Brnbrade asking for a detailed schema and others informations. Waiting for reply. Then I will post in english here.
Regards,
Doug
jacob
Quote from: z_p_e on July 02, 2007, 02:36:43 PM
I'm afraid I have big doubts about this device being ou.
Darren
Darren,
Unless there is a hidden wire somewhere, how could you possibly light a 50 watts bulb with such brightness with only 2 A cells?
Jacob
Bruce_TPU
Jacob,
If you  saw the orange wires soldered to the bulb leads, that does restore my faith, very much.  I am looking for some aluminum for I am going to build this two coil deal this week.
And then I will know.  I think there is sufficient information to replicate.  We just need to know if he still has the capacitor between the batteries and input.
Cheers,
Bruce
