The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
wattsup
@btenzer
That's one hell of a post #1 you put together. And soooooo quick. Geez.
If only my secretary could do that. lol
Honestly great work, thanks.
By the way, if any of the ECD guys ever offered you a circuit, ask for two.
@Brnbrade
Great work. Go have a bear. Don't worry about the noise here. This is only an internal form of communication between alot of smart people scratching their heads. Just do what you know how. Keep cool. We have alot of info for now to make a good replica, so life is good. Be happy. You are doing good.
Now where can I find two big nails..........
Bruce_TPU
@Darren
It is because he was a student of Erfinder, as Otto was. And he believes that is what Erfinder would want.  If you need to hear it in Portugese, that is fine!  ;)
@Wattsup
Thank you for the compliment!  Those come hard around here!  LOL
I still need help in figuring a guess for the fine wire.  If some human being out there can look at the first pictures, and you have experience with wire, and pm me the aproximates size, that would be awesome!  Thanks.
Cheers,
Bruce
Bruce_TPU
@ Darren
AND also Darren, to answer your question of how it is significant for the ECD, is an incredible question to begin with.
We/I want to incorporate as much of SM's clueology (new word! :) ) into the ECD.  If SM says that it will make a difference for the "tpu" and since no one is going to "draw a schematic" for us of how that works, we must "experiment".  And I suggest experimenting by doing Whatever is needed, to the circuit, to mimic a tube amp
Now, besides the look of the wave itself, here are a few other considerations.  (I am going to this trouble for all of you reading this, in the hopes someone can hear.)
Solid state switches tend to have a damped oscillation or spike on the leading edge of the wave. This spike is generally the creator of noise and harmonics.
Vacuum tubes - the leading edge would only rise to the plate voltage and chop off there. As long as the power supply was clean tube switches had very clean outputs. Those that used the heater element as the cathode would also impress the power for the heater element on the output waveform.
Study please more differences.  There ARE many.
Happy Days!  And good night...
Bruce   ;D
Earl
Hi All,
here is a revised drawing 2007-07-03.
Enjoy.
Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
MeggerMan
@Bruce,
Thin wire looks like 0.4 to 0.5mm diameter.
Thick wire looks like single core from 13 Amp twin and earth ring main cable (2.5 sq. mm?)
I think the reason the meter shows zero volts when the bulb is lit is because the meter is on DC and with a pure AC signal this will balance out to zero.
@Earl,
I think you may be right about the starter. From the patent you can start by moving the magnet into position, unless I read it wrong.
Has anyone seen Fig.2 on the patent?
I will be buying some hardware (steel rod, ali tube - rest I have) after work to try this idea out.
[Edit] Have bought some 10mm steel rod and 12mm OD ali tube - may need to file the rod down to get it in. Almost fits - first few mm.
This has so much in common with the TPU and from a patent thats 136 years old, wow!Ã,  :)
Rob
