The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
Earl
Hi Marco,
that is interesting.  Will see if Brnbrade or others can get it to work.  My image was drawn by looking at Brnbrade's photos, so he is definitely having some results.  One puzzling thing, it looks like he only has a voltmeter as load and that is not all that much to keep the action going.  The patent says the output must always be loaded after a kick start.
Also his first circuit presented is completely different than the present one.
Did you try both ferric and magnet cores?
Regards, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Jdo300
Hi Earl,
My setup only has steel cores on it. 1018 if I remember right. The coes are 2" in diameter so I never tried to find magnets that big to replace them with  :D.
God Bless,
Jason O
Bruce_TPU
Hi guys!
There are of course two individual coils with brnbrade.  Air core is what he has said before.
The solid 12 awg. wire IS the secondary.  He gives turns for this in my first post.
The thin braided primary wire IS the primary.  Elsewhere he said 1000 turns, but here he wrapped so that the total radius of wrapped wire is about the same of the core.
The primary wire is connected of each coil is connected to the opposing secondary via mobius fashion.
You can see plainly from the photos that the batteries go to a cap and the cap to the   coils.  Also can be seen how they connect.  The photos are very high resolution and can be blown up very large.
You can see the oscillations are input where he has circled.  I believe from previous post that he was stereo out giving him two channels.  The exact method from stereo to coil still needs to be found out, and I will work on that.
And that is pretty much it, other than he is going to put it on a bulb and take a picture. And at the same time take an Amp reading.
I for one, am facinated and have never seen something like this.  We will see.
Happy Days!  :)
Bruce
Jdo300
Hi Bruce,
It looks like you have a good understanding of this. Is the circuit in your mind the same as the one that Earl posted earlier?
God Bless,
Jason O
Jdo300
One more thing, how is the audio input connected? I can't tell very clearly from the pictures; is it connected across the battery input?
