The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
EMdevices
BEP
Maybe not errors. Either he studies electronic history or his accidents may be a plus.
Early detectors (around the time of cat whiskers on the edge of a razor blade) had nasty diode avalanche noise when you didn't have it right. Barkhausen may not be the only flipping going on here!
EMdevices
I'm using multiple small rods like wattsup
I cut them from a long bailing (iron) wire
I'll think about Barkhausen, and experiment some more.
EM
BEP
Thanks EM.
As usual I saw what I wanted to see But I still don't think you are seeing what I am. Yes, you are correct on the physical wiring but I will be testing what I believe to be the actual functional of the way it is wired and constucted.
i.e. The Aluminum reverses the induction field and if I remember right it isn't completely reversed. It shifts the induction by 90 degrees. As wild as it seems!
Large emergency generators use the same principal in the exciter windings for the field driving windings. They take the single DC drive current to create 4 distinct poles for the exciter.
I'll let you all know how it played out. If nothing else, you'll have a good laugh  :)
Bruce_TPU
IMPORTANT:
Hello All,  I have been reading and catching up.
I see that everyone has built there own version of the brnbrade coils, but NO ONE has followed the step by step directions that I have posted on page 1, post 1.
Brnbrade had told me in an PM that he was using Aluminum Varnish as his insulator.  Not tape, or anything else.  I ALSO listed the EXACT steps to take to build this.
Also there is ONE solid piece of iron in the center.  NOT many pieces.  So, with the absolute most respect to fellow builders and experimenters, I humbly request, that you build HIS coil first!  ;)  Get it working and then play!
PLEASE build again, this time EXACT directions.  I have been in ECD Land tonight and smoked a driver.  Will post a picture tomorrow.  And tomorrow I start on my brnbrade coil.
Happy Holidays!  (To my fellow Americans!)
Bruce  :)
