The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
otto
Hello all,
the vortex or how I call it, the tornado. This is the reason Im here.
In the patent is Al NOT mentioned!!!!
I readed the patent very carefully, NO ALUMINIUM!!!
But I can imagine that there are used 2 metals. In the TPU should also be 2 metals. For the moment we are using copper and Alu but I hate Alu. With Alu is the heat all over the TPU. With copper is the heat concentrated IN the copper.
In the patent was mentioned to use a ribbon spiral.
In the patent 119825 you can see that this ribbon spiral should be really thick....
Otto
Gregi
Hello CBCers,
Nothing special to announce, only that I built the coils.
What I have is on a d=0.2" (5.5mm) nail I put 5.2"(13cm) long AL tube and on it I wound 3 layers of 26AWG wire, on top 3 layers of AL foil and one layer of 13AWG solid wire.
Of course I put electrical tape for insulation where it should be insulated.
I only put 3 layers of the thin wire to try this out, since no one have tried it before.
Now, I couldn't make extended testing for the moment, because I don't really know yet how to use correctly a scope, and I don't have proper clamps and other stuff to connect the wires as it should be.
So I will order some labo wires, connectors, clamps and I will ask a friend to teach me to use the scope.  ;D
But since I am quite curious, could someone tell me where to connect the ground of the scope to be able see whats going on in the coils? But I have to tell that I don't even have a probe yet so its picking up a lot of ambient stuff... So for proper measuring I will have to wait until next week to get the stuff what I ordered.
Cheers,
Greg
PS.:what do you think about the 3 layers? I was told that its not so good because of the cancellation of the fields, and all...
chrisC
@wattsup & otto
It's easy to search inside the patent for your keyword by
1. goto   http://www.google.com/patents
2. Type in the patent Number
3.  Click on 'Read Patent'
4.  On the right side, in the edit box, enter your search word
5.  Found references will be displayed and marked Yellow like a Yellow marker.
Yes, there is no Aluminum reference in that patent.
cheers
chrisC
Doug56
@ All
Take a look in this video. See the detail in last picture. Looks familiar?
http://www.leedskalnin.com/Magneticinductionclip.html
BEP
@All
I stand corrected. The word aluminum does not appear in the patent. It does appear on a modified graphic that was an attempt to show how Brnbrade constructed.
I've been running so many numbers my brain is turning to mush. The aluminum was listed on patents from others.
