The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
Dansway
@brnbrade,
Alum....
Hm...
Now you have my attention.
How about a detailed schem so that we can try and replicate your design?
Thanks for sharing!
~Dan
Motorcoach1
well done Brnbrade: I built a cook coil years back and could not make it work. I've learned more sence then. in the original patent cook used kraft paper as an insulator. I never got the chance to do this but my next unit was to replace the kraft paper with a capicator in the insulator feild. doing this by takeing suranwrap (plastic wrap) and aluminum foil (thin stuff ) about 30ft long and roll it up on the secondary coil. this would help giveing a hard pulse the the primary.  Mike
Bruce_TPU
@ All
Please remember, with brnbrade's coils, His primary is of fine wire and is ON TOP of the larger wire, unlike you see in the patent.  ;)
And top coil primary, to bottom coil secondary.  Bottom coil primary to top coil secondary in mobius fashion.  The same on the other side.
Cheers,
Bruce
Motorcoach1
Bruce -Thank you I was trying to figure that out, I sure Barnbrade will post the build process soon so we can all expieriment with it ,sound like fun ! :D  Mike
bob.rennips
Hi brnbrade,
Bruce asked me to post a more detailed example of how to connect an analogue meter to measure the rectified current.
Hope this helps. Obviously this is just for a ballpark figure. We can add smoothing capacitors later.
bob
