Talking about phase...
Started by bob.rennips, July 01, 2007, 08:16:56 PM
MarkSnoswell
Quote from: Jdo300 on July 13, 2007, 09:56:09 AM...
The "second harmonic component" seems to line up with your idea of using x, 2x, x harmonics. Can the effect still work if all three frequencies are the same and just phase shifted?
No. In principal -- 3 in phase signals in 3 non-linked coils just vectorially add to a single component. You need independant control of pulse timing and the right coil design... but this is all based on work I have done simulating spinors. This work seems to fit SM and other devices better than any other theory I have seen but thats no guarantee that its right. Right now I am trying to extend my spinor generation software (a plugin within 3ds max) so I can search for higher order frequency relationships. I expect that exact phase timings will depend on the physical relationship of the coils -- there will also be different timings (harmonics) you can drive at given a single physical setup.
What is certain is that three independant components are required to create spinors. There is a huge range of physical ways to generate these components. There is also a corresponding large range of potential signal sets to create different spinors. As SM said -- start with one drive and then just vary the second component looking for maximum output... and then add the third and itterate to improve. After you have a set of timings that work then you can start to experiment with resonant feedback.
hm... if I get a chance over the next few days I'll put up an animation that makes this all clearer.
Mark.
PS. In some ways SM's TPU designs are sloppy -- at a guess about 10 years behind a competive technology. Although interesting effects seem easy to get *precise* physical designs should result in even more suprising effects. Whatever people make they should strive for very neat construction and be aware of small design changes that influence the output. As a hint look at Randal Mills work with generating Hydrinos and ask yourself how a low energy (reduced spin) electron from a hydrino would behave as a charge carrier in a wire.
Dr Mark Snoswell.
President of the CGSociety www.cgsociety.org
MeggerMan
Hi Mark,
RE: spinor_--_electrical_coil_analouge_-_45deg_helicies.jpg
Does this show 4 conical shaped vorticies of magnetic field?
Also this test coil:
http://marksnoswell.cgsociety.org/gallery/329928
This is a slightly different way from what is currently being looked at.
This is clever in that the green and yellow control coils have 1 turn vertically and 2 turns horizontally.
The red coil seems to be twisted in some way but I have no idea how you would wind it like that.
I have some ideas on getting on getting a variable duty cycle.
If my calculations are correct:
50% at 200kHz = 2.5 uSec.
But if the duty cycle is exceedingly small, say 0.5 % at 200kHz then your pulse width will be 25 ns, very short pulse. So short, that the mosfet driver and mosfet may not be able to keep up, given the rise and fall times for the components we have been looking at.
Perhaps mosfets are out and high speed transistors are in.
Can valves switch at these speeds?
So we have a physical limit on pulse width for the parts people are using, can you give an indication on the duty cycle required?
With your simulation, do the 4 x magnetic vorticies only appear when you have 3 frequencies in place?
Is the coil arrangement for the simulation as per your "spin half test coil" ?
Thank you for a new insight into what is happening with the TPU, I hope we can attack this from a new angle.
Your simulations certainly look as if they can at least prove the vortex idea.
Rob
giantkiller
Quote from: MeggerMan on July 13, 2007, 05:05:12 PM
Hi Mark,
Rob
It is wound very much like the mobius toroid. http://www.littlemountainsmudge.com/mobiuscontinuosknot.htm
Also there is no copper in the wires. It was done with 3dmax. The builders all concur: simulations and graphics don't cut it.
But they make great training materials and presentations to get the investigator up to speed.
--giantkiller. Not slammin', just jammin'.
MarkSnoswell
Hi,
     If I am on the right track with the spinor resonance then phase, pulse timing and coil configurations wont quite be what you expect -- that doesnt mean they will be complicated, but not what classical intuition would lead you to expect. Simple experimentation is called for...
I won?t have time to do experimental work on this project for a few months. I have some other projects to finish, an overseas trip and an office to move first.
If anyone is interested this is exactly how I will start. I?m giving instructions here so that others can try this if they wish. No guarantees -- this is just what I plan to do based on every bit of practical, hearsay and theoretical information I have to hand.
Construction:
1.   Starting with a single collector coil and primary. I would use some heavy duty coax for my collector coils as this provides a perfect core to wind the primaries on. RG218 is a good candidate. Cut 1196mm length and strip the outer sheath and remove the braiding ? this leaves the 15.7mm OD PE dielectric with 4.95mm OD copper core. The reason for using the coax is that you want precise and even spacing of the primary coil from the surface of the collector wire. I think this will work better than a stranded core ? it?s the precise/consistent spacing that is critical. Leave the striped coax straight for now.
2.   Wind a primary coil. I would do this on my lathe winding tightly with 1mm OD magnet wire over a  15mm OD steel former. After winding ? when the tension is released the coil will spring back enough to easily remove it from the former. It should slide snugly over the 15.7mm coax core you have prepared.
3.   The RG218 core is 5mm OD solid copper ? not very flexible and very hard to solder too neatly. For connecting to it I would drill 0.95mm holes radial into it right near the ends. I would then inert 1mm solid wire that I had sanded to a slight taper.
4.   Shrink wrap to hold the primary firmly in place. Alternately wrap tightly with a single layer of electrical tape.
5.    I would bend the completed collector with primary coil assembly over a circular former to bend into circular form. Tape the ends together and you can remove it from the form. The heavy copper core of the RG218 will help to stabilize the circle.
6.   *Variation: I would actually wind a perfect counterwound primary in anticipation of testing single primary vs counterwound. The reason for this is that we are interested in the spin wave front and not the B field generated by the primary. It may work better to eliminate the B field by applying the pulse to a counterwound primary. It is easy to wind a counterwound primary now and start testing driving just one helix. (I attached a photograph of the first counterwound coil I ever wound -- I found a novel way to make these perfectly and easily and made a whole lot of them a while back ;)
**OK -- you can also try a complete coax solution -- using the shield as the primary and core as the collector. In theory I thik this would work but the speed fo the spin wave front would be to fast to make for a practical design with a managable circumference.
Test procedure:
1.   Start with just one primary/collector coil.
2.   Connect the collector to a low impedance load ? a 100w incandescent light bulb.
3.   Drive the primary coil with the shortest pulse you can cleanly generate.  I would use a 600V MOSFET and drive with rectified mains voltage ~ 340V. I would use a good MOSFET driver like TC4421 and do everything else possible to ensure a clean fast pulse.
4.   Slowly sweep the drive frequency from 1Khz or so up to 100Khz looking for a peak in output. At this stage any peak should have a relatively low Q so it should be easy to find.
5.   I would then vary the pulse width ? looking to see if there is an optimum.
6.   I would repeat the previous step with single wound and counterwound primaries. I would try it with the primaries open circuit first and then closed to ground through a modest resistive load ? 1K ? 100K or so. The reasoning here is that we are looking for the optimum timing of the spin wave front pushing (SM talks about kicking and squeezing) a charge pulse down the collector == very fast circulating static field == very fast rotating magnetic field.
7.   After finding the optimum drive frequency for the first collector coil I would then add a second coil set. Space it one primary minor diameter above the first coil set ? that will be 15.7mm. I would use acetal or nylon spacers to hold the coil sets apart and tape them firmly together.
8.   I would series connect the collectors and check that with just driving the bottom primary things are working as expected. With the first primary (bottom coil set) running I would sweep the drive frequency of the second primary looking for further increase in the output. I would expect the Q to be higher now so I would sweep more slowly so as not to miss a resonance peak.
9.   I would repeat the previous step with the third (top) coil set added.
** After getting the three coil sets working as well as possible I would look at adding a bias coil around the whole set ? this is the single outer toroidal winding over SM devices.  I would use this winding to control both the static and magnetic bias environment for the three coil sets.
** All of this would be done with three independent signal sources. Only after getting everything tuned and working like this would I attempt to put in resonant feedback ? from one collector to the next primary.
** I would also repeat all of the above with three segment primary coils on a single colector and injecting the three frequencies into those three primaries on a single collector. I would try 3 primaries covering 120 deg and also 3 primaries covering 360 deg but tharting 120 apart.
If any of you are looking for control boards check out www.futurlec.com ? I would not use the http://www.futurlec.com/ATMEGA_Controller.shtml even though it has 6 independent PWM?s ? it?s too slow and you cant get good precise pulse width control over 10Khz or so. I am looking at using 3 of these http://www.futurlec.com/ARM7024_Controller.shtml and syncing them up.
Dr Mark Snoswell.
tao
Quote from: MarkSnoswell on July 14, 2007, 01:26:27 AM
Hi,
Construction:
Test procedure:
Impeccable...
I poster after my own heart.
Funny, you start posting here just as I am making my grandiose thread http://www.overunity.com/index.php/topic,2702.0.html , LOL.
Mark, it appears we have somewhat similar ideas, but use different terms/wordings ;)
