*The Study of the Practical Mechanics for a Working TPU*
Started by Bruce_TPU, July 05, 2007, 12:52:53 AM
Bruce_TPU
I will start gathering parts asap BEP.  I think I know a place to find the copper.
Motorcoach1
Thank you Bruce for opening this thread: The Egg- yes it is taught in Europe. We Americans have a system that dummies our kids down (across the grade spread) yea right! so much for that. dahh. I'm here to build !      OK I have a Question for BEP before i wind another coil this mt thought and should have done this from the start, when i wind the secondary - I wanted to  lose wind a cotton cord next to the wire winding so as i could easily set the capacitance. seams the secondary on most transformers are tight wound and thees great for fly backs but I don't see it working here were not trying to develop hight voltages in the KV range , but good clean BEMF , radiant capacitance. here I'm posting Photos my frame to receive the new coils. as you Noticed the aluminum tubing (gaped) . next step in the coaxial ( silverbrade) to be what SM said to be the collectors (Lorenz wrapped to frame) let me Know you thoughts . Thank you Mike
EMdevices
How beautiful !!!
Wouldn't it be nice if beautiful things just had to work, because they were so beautiful  !!  :)
EM
Motorcoach1
BEP on the -x-z and z in the three sistirs  --- listen to Leedskalnin  , we did this and it is real , take the wire project / THIS IS THE SAME AS ON A SCOPE actualy in real time the wire dances , When you put the voltage on the wire and put the iron next to it ( do this on 1 inch above the wire with steel strains ) it will follow thw mag wave down the wire and wiil look exacly like the scope shot. e/w n/s 90 mdegrees 45dr fresnal,25 degree rule ( I don't belive because Estine had a bad expirence on the Elkhart expirement) Time is expanded and contracted with in our own lives we just don't relize it . Bep has expened on it , yes time stops and begins , ok now back to the TPU issue .  first loop (control ) 6 loops in an H fasion not crossing . freq 4.5hz one cap and a doide not to have back BEMF to the coil, that goes to the next ciol and diode and cap relays to the nexy coil, stop the reaction in the third sa to the cap and diode is resonant to the tune cap and resistor .as to frqs just do the 1/3 Tesla as BEP ,    @ EM most things are of beauty wil kil you  mmmmm next step ------- nature does that  ask.. Frank LOYD Wright
