TEP replication
Started by Phil7218, May 25, 2005, 03:12:15 PM
Phil7218
Did anyone try to replicate the TEP circuit from the ctglabs
http://www.ctglabs.com/TEP_1_1.htm
http://www.ctglabs.com/TEP_1_2.htm
Which results did you recive?
I also tried to replicate it but I couldn't? measure an overunity effect
or any other strange effects.
regards, Phil
Thaelin
    I feel up to another toy to play with. I have all except the wire and the 1 ohmer.  22 gauge
wire should fit the bill and I think I could wind up a resistor. Check back as soon as I can get
it cooking. Would be a nice addition to the SG I have running now.
sugra
betajim
Hi Phil,
Quote from: Phil7218 on May 25, 2005, 03:12:15 PM
I also tried to replicate it but I couldn't  measure an overunity effect
The circuit on the website is only a DC to AC inverter with the output rectified.
I don't understand why the designer thinks the circuit is overunity. He also makes
the mistake of using a multimeter to measure an AC signal that isn't a 60Hz
sinusoid, because of this you can't put any trust in the meter readings.
Take care.
fallenangel3k
Aye,
I have. And I have gotten very well and very strange results.
Look at those XY-Scopeshots from Current and Voltage of the Load on this simple circuit:
http://www.wagner-beregnung.de/fallenangel3k/vortex2.jpg
http://www.wagner-beregnung.de/fallenangel3k/vortex3.jpg
http://www.wagner-beregnung.de/fallenangel3k/vortex4.jpg
http://www.wagner-beregnung.de/fallenangel3k/vortex5.jpg
http://www.wagner-beregnung.de/fallenangel3k/sei2.jpg Normal 2 channel scopeshot representative for above XY.
http://www.wagner-beregnung.de/fallenangel3k/sei1.jpg Full circuit in operation with ECO-Bulb as load.
I dont want to say anything about whether OU or not..... just that you MUST build this circuit.... it's very great for learning in either way... ;c)
Greets,
Marcus
PS: My own circuit has changes much, too. Now those big fat and nasty potentiometers are gone, it's a very small circuit now. But I made more changes... like solving the problem why you had to use two batteries before.... the current of the radiant energy is freewheeling (reads: dead-wheeling itself) in the coil. So you must place an other Switch on top of the coil which switches in same cycle as the other main switch. So both switches are either On or either off both. So you now can connect the output to input directly without having to worry about Battery-Resonance which would be required otherwise. So the energy can only go to battery or into storage-capacitor but not dead-wheel itself in the coil....
For a motor this is fine... this gives you more (free) power. But we want to charge batteries here!
saintsnick
Similar idea, capture back emf.
