0 Members and 40 Guests are viewing this topic.
ltseung888
Phone Call with an Electrical and Electronics Expert
Tseung: "I am interested in whether there are intelligent chips that can be programmed to exhibit the effect of a North Pole, South Pole or No Pole."
Expert: "There are the well known Hall Effect ICs that can be used to detect the presence and strength of magnetic fields.  Why are you asking the question?"
Tseung: "In the Dr. Liang Patent, he quoted China 3001 and China 3008 ICs were used to pulse rotate a cylinder to generate power.  We have the Lee-Tseung Lead Out theory you know about.  Can two chips be programmed to provide attraction or repulsion in theory?"
Expert: "I know you have good background in Computers.  Do you still remember the floppy disk?  The floppy disk uses magnetic technique to record the information. Your credit card also uses magnetic technique to record information. If you imagine two strips of magnetic material close together programmed to exhibit different magnetic poles, you get your attraction or repulsion.  I am not an expert on the China Chipset information as I never buy chips from China."
Tseung: "That is  great information already.  I shall share it with others on the Internet."
jeffc
Quote from: ltseung888 on August 21, 2007, 12:43:55 AM
Dear Forever,
Thank you for your translating the first two pages.  I am specially impressed with your interpretation of the second page reproduced below.
My (Forever Yuen) interpretation
There can be two cylinders. The inner cylinder can rotate and has one type of intelligent chips. It is also connected to the rotating axle. The outer cylinder does not rotate and contains another type of intelligent chips. ( In a later part of the patent, the two types of chips are refer to as China 3001 and China 3008) These chips are programmed to provide a pulse rotation.
Since the magnetic interaction is very small between two ICs. A large number of ICs are used. They are placed very close to each other.  Assume the magnetic interaction force between ICs is ?X?. Assume the total number of chips of one type is ?N?. Assume the rate of rotation is ?R?. If the diameter of the cylinder is ?D?. The energy is related to D times X times N times R. If typical value N= 700, R = 100 revolution per second, D= 0.5 meter . The total energy would be related to 35,000 times X. Even if the lead out energy is 50% of this amount, that energy is very significant.
This is the reason why a 188 horse power engine can be produced.
Please comment.
There are two comments I would like to make.  The first one is that the r=100 per second may be too high.  (6000 rpm).  I believe the more correct understanding is that r= 10 per second.  However, each IC may react with 10 other ICs in 1 revolution (If the 700 ICs are arranged in 10 rows).  The resulting number is still 100.
The second comment is that there are at least two more factors involved.  One is the mass of the rotating cylinder.  The other is the gravitational constant g.  The gravitational constant g can effectively be changed with your magnetic pendulum type setup.
Many chip experts know how to program the Hall Effect ICs and/or Magnetic ICs.  (I am NOT one of them.) However, few of those I know have ever thought about programming them to provide power.  They all wrongly applied the Law of Conservation of Energy.  They thought it would be pointless to use ICs to rotate the axle.  The energy loss and complications would not justify the effort.
The Tsing Hua University Professors and Students are the exceptions.  They believed in the Lee-Tseung Lead Out theory after a half day explanation by Lee-Tseung-Wang.
I shall wait for you to finish translating more pages before additional comments.  Please keep up the good work.
Lawrence
Thank you Lawrence, this is beginning to make more sense now.  Very interesting concepts.  I need to do some research on these ICs to better understand how they would be arranged.  Perhaps someone on this thread has experience with these?
Regards,
jeffc
chrisC
Quote from: jeffc on August 20, 2007, 08:11:39 PM
@Humbugger
I absolutely agree that this patent would not fly in the US or Europe.  The very purpose of a patent document, by definition, is that the invention can be easilly reproduced by someone with experience ("skill in the art") by following precise instructions.  It is not supposed to be a guessing game.
That being said, the quality of the patent document doesn't provide any conslusions about the invention itself, only a glimps into differences in the western and Chinese patent process.  IF the US patent office would grant me a patent with this level of detail, I would have done it as well!
Regards,
jeffc
These gentlemen are so full of themselves they only think of their postulates as 'Gospel'.
They forget the real world outside is not an 'opera' stage!
The US and European Patent Office will not even consider such things as patentable inventions! That's how far removed these guys are from reality...
cheers
chrisC
jeffc
Quote from: ltseung888 on August 21, 2007, 02:29:12 AM
Write heads on magnetic media devices like floppy and disk drives.  Hmmm.  The magnetic field produced by modern hard drive heads is quite narrorow compared to floppies and early HDs.  And tape drive write heads are a bit different set of properties as well.
Is the key here the relatively narrow magnetic fields as opposed to other methods which would create quite wide, perhaps "mushroom" shape fields?
Regards,
jeffc
Paul-R
I found this on "magnetic chips":
http://www.unisci.com/stories/20022/0614023.htm
Intelligent chips are harder; the name is used for
changing CD anbd DVD formats in some odd way.
Paul.
