0 Members and 44 Guests are viewing this topic.
ltseung888
Quote from: Pirate88179 on October 02, 2007, 01:57:04 AM
Lawrence:
I saw the slide show done by your friend. The results were not what I would have anticipated if asked beforehand.  Interesting.
Dear Bill,
That is why it is extremely important to actually do the Ms. Forever Yuen Experiment.  I shall explain the Lee-Tseung theory based on the results.  Those results can be reproduced easily worldwide.
If you have two magnets, a string and a stop watch, you can repeat it yourself.  The significance will be explained in the coming posts.
I managed to dig up some notes from my Tsing Hua Trip.  One of the possible integral treatment is now attached.  Improvement and further editing may still be required.
Lawrence
Actual Experiments Lead Out verifiable experiments.  The fast heartbeats or pulses may go back to normal.
ltseung888
The attached patent exchange document  It was used by us to argue our case with the PCT patent office.
I have edited the patent exchange document to focus on:
(1)   Gravitational energy can be lead out by a horizontal pulse force exerted on the pendulum bob from the stationary position (first pulse , Figure A1)
(2)   Gravitational energy can be lead out by a non-horizontal pulse force exerted on the pendulum bob when the bob swings to its highest position (second and subsequent pulses. Figure A2)
(3)   Gravitational energy can be lead out by any pulse force (may not be most efficient) exerted on the pendulum bob. (Figure A3)
(4)   Examples of working prototypes (Figure B1, B2 etc.)
(5)   The key point is Pulse Force can Lead Out Gravitational Energy.
Hope that document helps in the understanding.
ltseung888
Shielding
The concept of shielding is extremely important.  It is tied with the concept of CoE.
For example, if we could do gravitational shielding (which is NOT possible), we could:
(1)   Shield and raise a weight up to height h.  The effective g is much less than 9.8m/s/s.  The energy required is much less than mgh
(2)   Take away the shield and let the weight drop down to do work.  The energy that can be used is mgh.
(3)   Repeat from (1) and we have created a perpetual motion machine.
However, we know that we could do magnetic shielding or electrostatic shielding (e.g. with Mu-metal or flux change in coil).  What does it mean???  Are we creating energy or just Leading Out Energy???
Lawrence Tseung
Shielding Leads Out the possibility of perpetual motion machines.  This increases the Pulse rate.
Mr.Entropy
Quote from: ltseung888 on October 02, 2007, 12:09:26 AM
We assume that the Pulse Force is long enough to let the pendulum swing fully to its new position.  At the new position, the pendulum stopped momentarily to change direction to swing back.
Well, OK, but that is not a pulse force.  It takes a long time to get to the point at which it stops.
At the new momentary stationary position, Fs must be equal and opposite to the resultant force of Fp and Fg.
That is incorrect.  If the total force were zero, the bob would remain still instead of accelerating downward.
You are making the assumption that the force vector Fs [from the string] is always at right angles to the displacement vector D.  In constant circular motion such as the Earth going around the Sun, this is correct.  However, in accelerating and decelerating circular motion, this is incorrect.
As as long as the string is taught (and not stretchy), regardless of the accelerating or decelerating motion, the motion is at a right angle to the force from the string.  Strings are honest, in that they always point in the direction they are pulling!  And circular motion is always at a right angle to the radius.  That is why the string does no work (pulse force or not), why the lorentz force does no work, why the coriolis force does no work, etc.
As you have rightly pointed out, without the use of Integrals, we have to make certain assumptions and simplifications.  These assumptions and simplifications may be inexact or even incorrect.  Arguing over inexact or incorrect assumptions will waste much energy and time.
Well, I was talking about a pulse force.  What I said is also true for every tiny moment during the application of a longer horizontal force.  The integration is simply summing up all those little zeros to find that the string, in total, does zero work.
When I initially read your post, Lawrence, I was quite dissappointed to find that you had spoken so clearly, but incorrectly above.  You have certainly seem to have visited some knowledgeable people at Tsing Hua University -- people who certainly know what I'm talking about, and would not normally countenance those kinds of errors.
Is it possible that, before you started talking to them, you actually showed them something that worked?  That would cause them to be somewhat respectful, mistakes or no...  Perhaps you did.
Cheers,
Mr. Entropy
ltseung888
The significance of the Ms. Forever Yuen Experiment
Many of you have downloaded the PowerPoint presentation file of Ms. Forever Yuen.  Some may have repeated the experiment.  Some may have taken out the toy purchased from the Over Unity.com store.  Some may ask ? it is so simple, what is its significance?
Before I answer that, I shall quote a few significant experiments in history:
(1)   Galileo experiment of a feature and a rock falling at same rate in vacuum.  Previously, people believed in Aristotle?s words that a heavier object falls faster.
(2)   Newton?s Apple.  Millions and generations of people have seen objects falling to the ground.  Who established the foundation of Modern Physics?
(3)   Lee-Tseung Pulsed Pendulum.  Millions and generations of people have pushed the swing.  How many realized that the Push or Pulse could lead out Gravitational Energy?
(4)   Ms. Forever Yuen Magnetic Pendulum Experiment.  A toy is already available from the Over Unity.com store.  How many people realize its significance.
I shall list the significance of the Ms. Forever Yeun Magnetic Pendulum Experiment here:
(1)   We can Lead Out Electron Motion Energy (magnetic portion) by superimposing magnetic fields on gravity fields.
(2)   We can Lead Out Electron Motion Energy (magnetic portion) even without having any gravitational field.
(3)   We can use the repulsion property of the magnetic field to reduce the effective gravitational constant g from 9.8m/s/s to 0 or even negative.  This means we can make a device float or rise.
(4)   We can make the magnetic field in any direction ? not just towards the center of the Earth.  Our Cosmic Energy Machine can orientate in any direction.
(5)   We can turn the magnetic field on or off.  The magnitude of the field can be many times that of Gravity.  This gives rise to the Magneto Propulsion Unit that can power the Flying Saucer.  Nothing needs to be ejected out.
(6)   Our new space ships can be totally self-contained.  (Food, energy etc could be recycled.  Nothing needs to be ejected for traveling).
(7)   There will be a New Order for the World.  It is no longer the survival of the fittest.  Even the weakest can destroy Earth totally.  This will force the New Order of Mutual Respect and Coorperation.
Lawrence Tseung
Ms. Yuen experiments Lead Out New Order.  The Pulse Rate of World Development will be much faster.
