0 Members and 45 Guests are viewing this topic.
Earl
Hi All,
I have taken the liberty to convert the M$ doc file into open PDF format.
Regards, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
gyulasun
Dear Lawrence,
Thanks for the pulse motor concepts.  Can we possibly receive further info?
For instance, how Lenz law is minimized or eliminated?
Do the coils have ferromagnetic cores?
How much overunity have the builder of these setups measured? For the 225 HP motor for instance, what was the input power?
Is the magnetic shielding needed for the operation principle or it 'only' protects enviroment from rotating fields?
I think these are the questions first for me to explore further on and if you really wish to help ou developers on this Forum, you surely will receive much more questions.
Thanks and Regards
Gyula
ltseung888
Quote from: gyulasun on July 26, 2007, 08:03:06 AM
Part 1 - the pulsed rotation
Let me answer your question with multiple posts.  One of the key concepts that many OU developers often missed is that:
gravitational or electron motion energy can be Lead Out via Pulsed Rotations.
The rotor and stator set up was used to pulse rotate the inner cylinder or disc. A better way has already been found by Liang and Chao of China.  Both of them use Hall Effect ICs to achieve rotation.  See Slides 10 to 13 of http://www.energyfromair.com/beijing/taiwan2a.htm.
In both the Liang and Chao set up, the main energy Lead Out was gravitational energy.  Their inventions work best on downhill or level roads.  On going uphill, the available gravitational energy decreases with the angle of tilt.  At 90 degrees, the available gravitational energy becomes zero.  That is the reason for the bank of batteries in the Chao set up.  (Liang car just failed to go up steep hills.)
The Fifth generation Cosmic Energy Machines try to solve the problem by having the Hall Effect ICs in magnetic fields.  Lee-Tseung supply the theory.  The top universities in China are doing the implementation.
If you can read Chinese, you can get much more information from the Liang Patent.  (China Patent Application Number 01123526.8 ).
End of Part 1
ltseung888
Part 2 - drawing gravitational energy
An often asked question from the Students at the top Chinese Universities is: How can you be sure that you are drawing or Leading Out gravitational energy
The best answer to that question is to look at the First and Second Generation Cosmic Energy Machines by Sung Tim Fat.  In the First Generation, the axle was vertical.  The rotation of the three cylinders were in the horizontal plane.  400 watts was generated.
In the Second Generation, Sung essentially tilted the axle 90 degrees.  In other words, the axle was horizontal.  20,000 watts was generated. Sung was at a loss on such a big difference.  Lee Cheung Kin gained his confidence in early 2005 via the simple explanation:
in the first generation, the device used the magnetic field of the Earth and magnified it via the three cyclinder rotations.  In the second generation, the device used also the gravitational field of the Earth.  A simple tilting experiment with the second generation showed the decrease in power.
Details the Sung Tim Fat invention can be found in China Patent  Number 99126283.2.
End of Part 2
ltseung888
Part 3 - achieving the desired rotational speed
The output of the pulse motors depends on the speed of rotation.  There are two alternative techniques to achieve the desired rotational speed.
(1) Use a separate starting motor to get to the desired rotational speed.  This technique was used in the Sung, Liang and Chao inventions.  The pulsed rotation control is simpler as the pulse rate does not need to change with the rotational speed.
(2) Use a varying Pulse Rate to accelerate the device to the desired rotational speed.  I believe this technique is used in the 225 HP Pulse Motor as it has a good Pulse Rate Control mechanism.
Both of the above systems used starting batteries that could be removed after operation.  Battery power is used to power the ICs or the electromagnets.  In case (1), battery power is also used to power the starting motor.
End of Part 3
