ltseung888
Preparing the Team for the big event.
The thoughts from the ever supporting Daniel Tseung
Dearest Friends,
While I am still somewhat embarrassed by this, I would like to share with you my video testimony on "Ambition as a Christian" from last Sunday's Island ECC service.
Please visit the Island ECC website --->http://www.islandecc.com/worship/series.htm and click on the Aug 23 2009 Video titled "On Location, The Non-Sabbath".
I hope this video might help you think about those things in life which you are now "ambitious" about and whether those things are really the things which God is "ambitious" about.
Blessings, Daniel
Devil
Tseung et al, I know that you have two working lead-out energy machines generating more than 0.5 HP.  One will be delivered to a factory for production testing and production.
You are testing some large wheels over 2 meters in diameter.  Early results indicate that you are on the right track.  One prototype broke because of too much output power.  You still have not done the programming to reduce power on reduction of external load.
You think that you are on the right track.
Morally, your team is on the wrong track.  Your team will drift apart because of the temptation of money, prestige, greed and words from the outsiders.  Some investors will tempt you.  Some business brokers will mislead you.  People will lie or distort your words.
Can your team survive?  My followers will crawl over you.
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
ltseung888
The attached good looking prototype will be sent to a factory for production evaluation.
It has 8 magnets on the wheel.  It has 4 coils that can be turned on or off individually.  It has a proximity switch that can vary in position to turn the wheel faster, slower, off or even backwards.
The much more conclusive overunity lead-out energy wheel with diameter more than 2 meters will be shown after it is repaired and improved.
The vision of having the Leaders of the World starting a Lead-Out Energy Machine to solve the Energy Crisis is another step closer.
ltseung888
The 5KW prototype will have the following features:
1.   !6 Magnets (2 times the power of the Educational Prototype)
2.   15 Coils (3.75 times the power of the Educational Prototype)
3.   Diameter 8 times that of the Educational Prototype (8 times the power)
4.   Two 12 Volt Batteries (2 times the Input Power)
The Output Power is expected to be (4 x 3.75 x 8 x 2) or 239 times the power of the Educational Prototype.  We only need 5KW to satisfy the demonstration criteria.  The much larger wheel also allows more time for the Lead-Out Energy to take full effect.
The demonstrated Output Energy can easily recharge the batteries and light many 100 watt bulbs.
The small 30 cm diameter Educational Prototype can be shipped easily.  It is safe for Educational Demonstrations.  It will light some LED lights.  But for practical power generation, large wheel is preferred.  We do not need to increase the diameter too much because we can also stack two or more wheels similar to the 225 HP Pulse Motor.
ltseung888
If the large wheel has such good advantage, why was it not developed earlier?
It is a matter of the theoretical scientist verses the practical engineer.  The scientist wanted a large wheel with diameter at least equal to 1 meter (the same as the 225HP Pulse Motor).  The engineer wanted a small prototype (1/3 the diameter or 30cm).  When it was a matter of illustrating Lead-Out Energy, a small prototype was sufficient.
When the scientist has no money and relies on the resources of the engineer to complete the prototype, it was a case of â€" the one with the gold wins.
Now, the prototype is successful, investors want to see “the practical machine”.  The scientist wins.
With the large wheel, much more loss of energy can be tolerated.  Many home-inventors can copy the design and re-invent the Lead-Out Energy machine.  The World will benefit from this technology.  No Government can stop it now.
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
