ltseung888
The Input Waveforms
The readings were taken with 6 Collector Coils in series and 9 Drive Coils in Parallel.
Overunity is again confirmed - with actual readings and displayed waveforms.
ltseung888
Output Waveforms
The corresponding Output waveforms.
Meters do not lie.  Overunity is confirmed.
Input is effectively measuring the effect of 9 Drive Coils.
Output
is effectively measuring the effect of 6 Collector Coils.
ltseung888
Two new prototypes to be built at IVE
Ir. Chong and Ir. Lo were confident with the results.  They decided to built two prototypes with two teams at IVE.
Ir. Chong will handle the smaller prototype with laser sensing.  He felt that the much sharper control with laser or light sensing can help to keep the prototype small.  He will experiment the new laser control mechanism.
Ir. lo will handle the larger prototype with Proximity Switch.  The wheel will have rods that can be replaced to produce different effective diameters. The wheel will be placed horizontally and will only have one non-moving side.
When ready, we can loan our original prototype to other educational institutions.  The earliest time will be after the DEC 3-5 Expo.  We expect similar responses.
teslaalset
Lawrence:
Thanks for showing your progress.
I have a few questions on your feedback:
1) to fully verify input power and output power from the oscilloscoop pictures we need to be able to know the actual time and amplitude scale of the measurements. Is it possible to provide those?
2) Looking to the output wave shapes: The rectified voltage wave shape is what I would expect.
What was the actual load that was applied during the measuements? A light bulb? In that case I would expect the output voltage wave shape to be simular to the wave shape of the output current wave shape. Can you explain why there is a difference in output wave shapes?
ltseung888
Quote from: teslaalset on November 24, 2009, 10:13:36 AM
Lawrence:
We were focusing on the general shape of the wave form.  The readings were taken with no external load.  The expensive oscilloscopes have inputs to the computer containing programs to do various analysis.  We had some problems in setting that up.  Thus we use the meters shown instead. We shall display the scope results and analysis at a later date.
In addition, we used clips and wires to make connections.  That had significant resistance.  If you note the Output current reading carefully, you would find that the hertz value displayed was half that of all other meter readings.  With no external load, we should read 0 amps.  But we got a very high amp reading. Thus that particular reading should not be trusted as some type of leakage effect could be taking place. We shall do the tidying up before doing and providing the final figures.
The good news is that we could recharge the rundown 6V batteries with the present setup.  The bad news was that we could not recharge the rundown 12V batteries.  We are investigating why.
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
