ltseung888
As advised, we are putting much more information related to the Open Shows for all to view.
Here is the presentation by Ms. Forever Yuen in Chinese.
http://www.youtube.com/watch?v=ZkEc5gJwUhc
ltseung888
Weight Reduction
We now can build an Overunity Lead-Out Energy Machine generating 1 watt weighing less than 20 kg.  We just need to confirm that the batteries can be self-recharged.  The meters say so but we want to make sure the batteries were not degraded.
mscoffman
Quote from: ltseung888 on November 29, 2009, 08:58:21 AM
Weight Reduction
12Vdc batteries should charge ok- if an open circuit voltage of 13.8Vdc is applied.
An uncharged battery will pull this down due to it's internal resistance then
then the voltage will rise as the battery charges up. You can use a nearly 1:1
step up transformer to boost an AC signal slightly if you need more voltage...
but don't over do it as, as you step voltage up the current available decreases
by the same ratio.
Don't worry about building big machines. Remember that the current average
home power usage can be supplied by *only* 1.5KW machine operating continuously
into a 26KW automobile sized averaging buffer battery. Even 5KW continuous
is probably too high to start with. This 1.5KW is not very much.
Forget about the 1MW, 10MW, 100Mwatt models, the folks who could make use
of these will tell you they can already generate electrical energy.
:S:MarkSCoffman
ltseung888
One way to increase Collector Coil efficiency by over 10 times
At present, our collector Coils do not have any soft iron core.  If we put soft iron core in at the beginning, the coil will be attracted to a permanent magnet on the wheel.  The wheel will not rotate at all.
The Output Voltage and Current are AC.  The question is â€" if we insert the iron core after the wheel has started rotating, what would happen?
It was a simple test.  The soft iron core was subjected to AC current and it no longer gets attracted to the permanent magnets.  The Output AC voltage increased over 10 times.  In our early test, one Collector and 4 drive coils on the small model yielded an Output Voltage of 12 Volts on no load.  If we place a magnet at the open end of the soft iron rod, the Output Voltage increased.  The highest we measured was 38 AC Volts with 3 strong magnets at the open end.
One way to control the Output Voltage and Current was to move the soft iron rod in and out of the Collector Coil!
We need to do more to confirm the above.  If confirmed, the size of our overunity machine can be much smaller.
Lawrence Tseung
Director
Help Seedling Innovate Foundation Limited.
Pirate88179
Lawrence:
Check out my youtube video where I made one of my Bedini motors with an adjustable coil/core distance to the rotor using a threaded rod.  It works really well and you can make very fine adjustments in this distance, within a few thousands of an inch.
http://www.youtube.com/watch?v=cRO8Pdh35bA
