0 Members and 51 Guests are viewing this topic.
teslaalset
Quote from: ltseung888 on November 29, 2009, 04:13:12 PM
At present, our collector Coils do not have any soft iron core.  If we put soft iron core in at the beginning, the coil will be attracted to a permanent magnet on the wheel.  The wheel will not rotate at all.
Lawrence, I think I might have missed something, but I think this is not what happens in such a motor.
If a magnet on the wheel approaches a collector coil with an iron core it gets attracted first, causing acceleration. Then passing the coil the magnet will be attracted in the opposite tangential direction, opposite to its actual movement and by that slowing down.
The sum of these two forces should equalize.
(at least with no load to the coil)
ltseung888
Quote from: Pirate88179 on November 29, 2009, 04:48:20 PM
Lawrence:
Check out my youtube video where I made one of my Bedini motors with an adjustable coil/core distance to the rotor using a threaded rod.  It works really well and you can make very fine adjustments in this distance, within a few thousands of an inch.
http://www.youtube.com/watch?v=cRO8Pdh35bA
Thank you for the useful information.
In our case, we have a soft iron rod inside a plastic cylinder.  The Collector Coil was wound on the outside of the plastic cylinder.  We could pull or push the iron rod in and out to get different Output Current and Voltage.
Pirate88179
Lawrence:
Yes, I see.  You could possibly glue a threaded bolt to the core and mount a nut on the end so you could make fine adjustments when needed.  That's a similar approach to what I did, I just watched the meter and adjusted for best output.
ltseung888
Quote from: teslaalset on November 29, 2009, 04:48:58 PM
At the start (before the wheel rotates), if we put a soft iron rod close to the wheel, it will be attracted and attached to one of the powerful magnets in our rotor.  If the rod is inserted into the empty core of our fixed collector coil, the strong attraction between the permanent magnet and the iron rod will prevent the wheel from starting.
For a long time, we avoided the use of soft iron core.  Yesterday, we decided to try the technique of starting without the soft iron rod.  The wheel rotates in the normal way.  We then inserted the soft iron rod into the cylindrical core of our Collector Coil, we did not experience any net attraction or repulsion.  That was expected theoretically as the the soft iron rod will change poles rapidly.
The surprising event was using the suggestion from Gaby long ago.  Put a strong magnet at the end of the iron rod (any polarity) to influence the magnetic flux.  To our delight and amazement, the Output Voltage increased significantly.  We shall investigate this more after our Open Show on Dec 3-5.
Devil
Learning together with the World
Tseung, you are extremely generous in sharing your experimental results on a daily basis with the World.  Some will surpass you with their superior resources and support.  You may never get a World-wide patent once you disclosed the information.
However, your progress history may be a very valuable lesson to all new comers.  They will realize that the invention path is long and bumpy.  There are jeers from debunkers and insulters.  Some of them are paid to lie and mislead.  The existing Interests will not lie down without a fight.
You can view your project as playing the game â€" Free Cells â€" on your computer.  When the end game is near, many will be able to spot the obvious moves.  You are in the end game stage now.  Success is virtually assured.  At the beginning of the game, there is no certainty that you will succeed.
You are lucky because you started with the Lead-Out Energy theory.  You already understood the importance of providing and controlling the Pulse Force.  You never blindly follow the footsteps of Newman, Bedini, Wang or Liang, etc.  (In a way, you avoided following the blind.)
After the technical evaluations, you will meet the more unpredictable political challenges.  Someone will claim that they have invented the Lead-Out Energy Machine long before you.  Or some copycats will ignore all patent protections and rules.
If you truly want to benefit the World, be prepared not to receive any rewards in whatever form.  Can you and you team really do that?
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
