0 Members and 38 Guests are viewing this topic.
ltseung888
Part 9 - Use of magnetic shielding material
The use of the Pulse will rotate the rotor pass the 'sticky' spots.  Thus there is no need to use magnetic shielding material.
Magnetic shielding material is expensive and difficult to handle.  It will help in marginal cases.  With pulsed rotation, we can avoid such expense and complexity.
From my understanding, the 225 HP pulse motor did not use magnetic shielding.  The Sung Tim Fat and Wang Shum Ho devices used magnetic shielding.
End of Part 9
ltseung888
Part 10 - Feedback Circuit
Once the Pulse Motors achieved feedback, they essentially generate electricity without any more input.  It would be meaningless to talk about Coefficient of Efficiency. (Output/Input power).
However, we have to worry about a different problem - energy buildup.  If the Output Load is reduced, the device must pump out less power.  There must be sufficient power to provide feedback.  Excess power must be avoided to prevent overheating the device.
Good control circuit is necessary.
End of Part 10
ltseung888
Part 11 - how Lenz law is minimized or eliminated?
From the Lee-Tseung Lead Out theory, the Pulsed Rotation alone is sufficient to Lead Out both gravitational and electron motion energy.  There is no need to introduce new concepts to explain the source of energy.  The Law of Conservation of Energy is NOT violated.
In some Pulse Motors such as the Liang and Chao devices, no coils nor permanent magnets were used.  Lenz Law was not applicable.
In the case of TPU, the pulsed electromagnets introduce electron movement along the torroid.  Using layman languages, if the Pulse Frequency is correct, the 'Pulse' travels around to add to the 'push' of the electrons.  This helps to build up the electric potential or voltage so that the TPU can generate electricity.  Note that it is Pulse Frequency and not alternating current frequency.
Thus we are not introducing new concepts such as back emf, magnetic lag, magnetic viscosity, zero point energy etc.  We believe such concepts might be useful to the inventors in their explanations.  However, we believe we can explain the working of their inventions from the Lee-Tseung Lead Out theory alone.
End of Part 11
ltseung888
Part 12 - Answers to direct questions
Quote from: gyulasun on July 26, 2007, 08:03:06 AM
Do the coils have ferromagnetic cores?
How much overunity have the builder of these setups measured? For the 225 HP motor for instance, what was the input power?
From the pictures, the 225 HP motor appears to have ferromagnetic cores in the coils.  The coils are not hollow.
From the pictures, the 225 HP motor appears to have 4 car batteries used to start the rotation and power the coils.  However, these batteries will be recharged by the device and can be disconnected afterwards.
End of Part 12 - (End of reply for now.  Any more questions?)
gyulasun
Dear Lawrence,
Many thanks for your lengthy comments in 12 Parts, and although most of the texts you included are also available in the link you referred to,  I do appreciate your efforts.
Perhaps the most important question, Lentz law in the pulse motor concept you showed, is what I missing: I cannot really make out any answer on that from you.  I quote your answer from Part 11:
Quote from: ltseung888 on July 26, 2007, 09:59:30 PM
The reason I say this is that you showed using coils for the pulse motors in the DOC file and whenever a coil with a load and a permanent magnet interact, Lenz law manifests. And it is here where your kind answer is missing.  I understand if you cannot include a practical solution which must have been used in case for instance the 225 HP motor from which you wrote it would self-run after the startup  but once you wrote:
Quote from: ltseung888 on July 26, 2007, 06:22:15 AM
We want to benefit the World.  The first group we target are the Over Unity Developers.  We want them to understand the Theory and thus feel more confident in their inventions.
Attached is the updated file from Forever Yuen related to Pulse Motors.
Comments are welcome
I think the question of Lenz law elimination is important. Or if it is NOT the elimination of the Lenz law in the output coils, for instance, in case of the 225 HP motor but something else then it is this something else which does not turn out from your kind answer.
Maybe others see this differently, maybe I am missing something to understand how Lead Out Theory explains this, sorry.
Thanks for the answers for my other questions.
Best Regards
Gyula
